Question about Rms Teflon Tubing - 38-16 - Tennis Racket Stringing Machines
What is the size of teflon tubing for grommet repair
2002 Honda Accord. The sunroof's vinyl drain tube on the driver's side has shrunk or pulled back at the bottom end approximately 1.25 inches pulling away from the molded rubber grommet near the kick
here are some pics of your problem,you could get a new tube from honda or a new tube from a hardware store,disconnect the tube from the top,tape the new tube to the top of the old tube,tape it good,pull the old tube out the bottom and attach the new tube at the top and to the grommet on the bottom,OR you may be missing the grommet,get a new grommet or,use a straw from a plastic cup and attach it over the old tube and insert through the hole in body.,25351676-4xvsciucyrxwqvq5ys1rwwmi-2-0.jpg 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-2.jpg 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-5.jpg 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-9.png 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-14.png 25351676-4xvsciucyrxwqvq5ys1rwwmi-2-20.png
Jan 02, 2015 | 2002 Honda Accord
How do I repair a Teflon tube on NESPRESSO Pixie COFFE MACHINE
You purchase the correct tube as a spare part from a supplier. Give your model to Nespresso and ask for direction.
Dec 20, 2014 | Frontgate Nespresso Pixie Brown Machine -...
Plymouth 1967 vent for gas tank what holds the
The grommet's it on the tank side, and there's clips that hold the tube to the side of the fill tube.
Sep 24, 2014 | Plymouth Cars & Trucks
Oil leak around oil filler tube
There is a large rubber grommet on the bottom of the oil filler tube and it may be cracked or missing. Some of them have a rubber o-ring instead of a grommet. Hope this helps.
Nov 03, 2012 | 2002 Chevrolet S-10
I lost the rubber grommet for the earpiece for my Samsung WEP490 bluetooth. Where can I buy spare rubber grommets?
Go to the hardware store and look through the O rings for faucet repair til you find one that works. I got a #1 size.
Jul 11, 2011 | Cell Phones
Water does not stop pouring from water/ice dispenser. Door-to-door GE Profile Refrigerator Model TFX22PPDACC. How to troubleshoot the problem? Or what part need to be replaced?
With the water running tube/pipe is cracked in between or its got loose from its fitting.First inspect the line for this problem.The tube from which water passes, one end is connected to the water valve at the back base of refrigerator.And then from valve two tube runs.One tube is for water dispenser and another tube is for ice chamber filling.Follow that tube from back of the refrigerator.The water dispenser tube That passes through the freezer door also.And the ice maker tube.That connects to the back of ice maker tray.The water fills in the tray.See if that tube is got loose and its not throwing water out instead of ice maker tray.Many a times this happens.--- May be you need to remove the ice maker to get exact location for tube setting and position.----------- But if tubes from water and ice dispenser sections are fitted properly and then there can be crack in the tube.------------But if tubes checked out ok then other possibility can be faulty water fill grommet.------- The grommet is cracked.And that is causing the leak.--------- Go to the back of the unit and remove the cover at the lower right of the unit. This is where the water line goes into your unit. Remove the water line at the solinoid that goes to your ice maker . This will allow you enough slack to remove the old water fill tube and replace it with the new one.
You need to push the white retainers in to release the tubeing from the solenoids.
The part you need is called fill tube grommet.It has to be removed and replaced.The tube is connected to the grommet. Click this link below for more help:---http://technoanswers.blogspot.com/2011/06/how-to-remove-ice-maker-fill-tube-from.html
------------ The other possibility for this leak, is water valve.The water valve close and open.When its open, it lets water to the tube.When it closes it stops water.But if the valve is not closing then it will let the water to enter non stop, slowly --- slowly the inside tube getw over filled and then starts leaking.------------ The water valve is not required as per the problem.But if after doing all the repairing, still the same problem, noticed then water valve is required.Because is water valve is not closing properly, then it leaks some water, (drop by drop) and this can cause water to collect in the grommet and this gets formed into ice and the same leaking repeats.---------but at present dont buy water valve.Just keep an eye on this same problem.sometimes leaking will start after few days.In that case also replace water vale.------- Now for other parts, that are extension hose,icemaker tube and clamp.Out of this you will require clamps, sometimes while removing old tube the clamp gets cracked.you can buy this.The extension hose is required if the tube is getting short or actual hose is cracked in between.i dont think you will require extension hose at present.And for ice maker tube.This tube can also be cracked and cause leak.this tubes by time gets bit swollen and loose its grip.Its actually not required.But if you still replace it, that it will be good.--------so you can order clamp and icemaker tube with the grommet part.----------- The parts which you want to order, this is direct link for parts:-- 1. Dual Inlet Water Valve------------ (http://www.partselect.com/PS901314-GE-WR57X10051-Dual-Inlet-Water-Valve.htm)
2. Icemaker Water Line ----------
(http://www.partselect.com/PS299643-GE-WR2X9245-Icemaker-Water-Line.htm)
3. Icemaker Fill Hose Extension ----------
(http://www.partselect.com/PS298725-GE-WR2X7927-Icemaker-Fill-Hose-Extension.htm)
A fill tube clamp for the fill tube grommet----------------
(http://www.partselect.com/PS297951-GE-WR2X4754-Fill-Tube-Clamp.htm) ----------- This will help.Thanks.Helpmech.
Jun 16, 2011 | Refrigerators
Why does my PCV valve and grommet keep popping out of engine? New PCV valve, I wrapped the grommet in teflon tape. Was real tight, still blew out.
It sounds like the line from the PCV valve to the engine is blocked. Double check the valve itself, it should rattle when you shake it. Put it back in but don't connect it to the intake. If it doesn't blow out check for blockages in the line between the PCV valve and the intake or possibly the entry hole inself. Hope this helps.
Oct 24, 2010 | 1986 Ford Crown Victoria
Dry rotted tubing on my weedeater blower.
Have it replaced at a lawnmower repair shop.
1.) Have them check the grommet (black round rubber like a thick coin with 2 or 3 holes), replace it if it is crumbly. It holds the fuel line and the fuel vent line - if your trimmer has it. Grommets on the average cost about $6.00. Not all trimmers have fuel grommets, some of them only have holes right on the fuel tank. 2.) Replace the fuel line with Tygon fuel line hose. Tygon can withstand UV light, petroleum, high and low temperatures while retaining its shape. Just make sure the replacement tube is of the the same inside diameter. For a small piece of Tygon hose, ave. cost no greater than $8.00. 3.) Replace the fuel filter. The one inside the tank, connects to the end of the fuel line. Fuel filter, good ones are about $4.00.
Aug 23, 2009 | Garden
99 Boxter horn
The horn grommet retainer frame must be replaced due to detiorization of rubber spacers.
Jul 05, 2008 | 1999 Porsche Boxster
Poor print quality - halo/smudge effect
maybe the probem lies in the fuser this is a metal teflon coated tube (surrounded in fidly breakable plastic) with a halogen light running through the middle (for heat) it heats up and fuses the toner to the paper JUST before it leaves the printer (thats why the paper is hot when it leaves the printer) you can have the tube RE-tefloned for not much cost when i used to repair laser printers the company would post a re teflonned tube and i would send mine back so the client would not be without a printer while the tube was being re done - or you could just buy a complete new fused unit (not cheap) hope this helps
Feb 14, 2007 | Kyocera Mita FS-C5016HDN Laser Printer
Rms Teflon Tubing - 38-16 - Tennis Racket Stringing Machines Logo
774 people viewed this question
Top Rms Sport & Outdoor - Others Experts
Are you a Rms Sport and Outdoor - Other Expert? Answer questions, earn points and help others
