Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Asus m2n E Sli board audio
Just put a new M/ Board in pc and no way can i get rear audio to work, front speakers are ok but tried all sorts to get rear ones to work , Anyone had this problem ?
  • 2 more comments
  • Deezel69 Oct 12, 2007
    Yeah it's the c-media driver, thanks for trying anyway ,I've give up and will buy a proper sound card soon
  • Anonymous Mar 20, 2008
    no sound
  • longrifl Aug 17, 2008
    sound was fine now. No sound says no Audio Output device installed
  • Anonymous Aug 27, 2008
    Yes. Mine is a M2N-SLI, and I observe same problem. If you connect the headphones, you cannot use the speaker's output. I didn't solve yet the problem, but it seems just a connection problem-.
Hi all. I've just recently upgraded my tower to a coolermaster stacker. It's a Maxi tower. Any how I've got the honor of having an Asus M2N E -SLI Motherboard, I had a lot of trouble to get the sound working, so I just removed the drivers to the CM 6501 Audio card thing....you know what I mean. So instead of using the HD audio I took the ac'97. And gues what It works on both front audio and rear audio output.
Posted on Jul 23, 2008
I had the same problem, and it went away when I connected the the front speakers via the 'ac97' connector from the case, instead of the HD audio connector. It seems using the HD audio connector, as well as using no connector and forgetting to put back the jumpers originally set over 2 of the front audio connectors pins, will cause no audio from the back ports.
Posted on Dec 29, 2007
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Install the SoundMax drivers from www.asus.com and ensure the "autosense" feature is checked.
Posted on Oct 10, 2007
  • Paks Dm Oct 10, 2007
    Install the SoundMax driver software from www.asus.com and ensure the "autosense" feature is checked in the preferences.
    Habit-Forming:
  • 188 Answers
Check all sound settings... by ur controle panal just try to set oll default man.,. if it doesnot work then u have problem on ur motherboard.... u can also download u r motherboard manual by net for ur own help...al real motherboard settings will be there.. best regards.. mail-sigma_shiva1@yahoo.co.in
Dual board SLI does not work.
I replaced lamp,now the light blinks six times red. when i try to turn the tv on it takes 20 times, each time it takes more ? can this be a d-board?
Mar 28, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Sound issues
both ports are integrated audio, both feed off the motherboard, the front ones come off a combo header with hd power lights,
on the back you should have 4 speaker out (surround sound), line in, mic in, 4usb2, 1firewire, 1ethernet, 1parallel, 1vga, 1rgb, 1ps2 keyboard, 1ps2 mouse
fffaab4.jpg try a different speaker out,
you may be attached to one of the fillin ports for speakers that go behind you in surround sound
pink is mic
light blue is line in
light green is headphone/plain stereo
yellow is subwoofer
dark grey is wide
light grey is rear
Jul 18, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
SLI Video Cards
Enter you're bios & open you're manual to page 4-32. Set you're
configuration to dual video card. Use the AL software to tweak you're settings in windows. If you find this not helpful than please call Asus tech at: 1-812-282-2787, M-F 8:00AM-5:00PM EST. Unlike other companies you will not be on the phone very long. Please have the S/N of the board handy. This is located on the board, on the LTP port (White sitcker).
Good Luck!
Mike
Jun 09, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Audio deosn't work on mobo
Hi Chris, the problem can be one of two issues. If the sound jack located at the back of the PC did function at the same time as the front case sound jack. Than the problem is the jack it's self is bad. (Back of PC). Someone had to hook up the front mic & sound jack to the motherboard. So disconnecting the front sound & mic may give you rear sound & mic.
Turn to page 2-29 in you're user manual for the Asus M2N-SLI. The pic shown is the default setting for the front case audio & mic. (What you do see are the two jumpers connected). So disconnect any connector & place a jumper over pins 9 & 10, (last two pins at the right of the two rows of pins). Place another jumper over pins 5 & 6.
Pin 1 is the first pin on the left bottom row (MIC2). Pin 2 is the first pin, left edge top row (AGND). Pin 8 is not installed but you still count its spot as if there was a pin. (This is how the board was setup from factory). Once you fix this you should regain sound & mic function at the rear of the PC. To fine tune the audio run the Asus sound effect manager. If you installed this software, (Recommended). If it’s not by you're clock than it’s in control panel.
Link to all for M2N-E SLI
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Good Luck!
m
Jun 07, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
On board audio problem
Hi, do you have you're manual? The answer to you're questions are there.
There are three femal plugs on the back side of the motherboard for sound out-put/mic-output & sound in-put. There ia also the option (For most cases), front plugs. Sound = out & mic=out.
See page 2-22/2-23, for rear connectors (What goes where).
Goto to page 2-29 to see Front panel audio connector (10-1 pin FP_Audio).
If you do not have you're user manual you can download it from Asus. Click on the link below.
Have more questions? Please feel free to ask.
Good Luck!
Mike
May 02, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus m2n-e sli Cpu changed settings on boots up
I could not find BIOS ver. 1302 for the M2N-E Mb. What I do know: Your dual core 4200 showing up as "unknown". Asus says:
This is because the BIOS does not have the relative CPU uCode to support this processor. Please simply update your BIOS to version 0902 or later to resolve this problem.
BIOS 0902 can be downloaded from the link below:
http://dlsvr01.asus.com/pub/ASUS/mb/socketAM2/M2N-E%20SLI/0902.zip
Once you cpu shows up correctly, chances are that your over clocking will work and the bios will stop sending you back to change your settings.
Dec 11, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N E SLI Boot and Audio Problems
I would check if there is an updated BIOS available for your board, as this may help
Dec 04, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No display when i boot up
Can you tell me , Whats the changes you made in CMOS , while assembling the Pc
Aug 28, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
10,025 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
