Question about Logitech X-240 Computer Speakers
How do i wall mount logitech x-240 - Logitech X-240 Computer Speakers
How do I change the 3 prong wall mount to a 4 prong wall mount for a dryer?
Since you are asking, I would not suggest you try it. 240 volts is deadly. It would be easier to change cord to 3 prong and then add grounding wire from back of dryer to cold water pipe. The 4th prong is a ground connector, new standard for safety. Your house wiring may not be set up for it, or it might be. Unless you know what you are doing, let someone who does do it for you. Be safe pls
Mar 06, 2015 | Dryers
How do you wire an air compressor from the wall to compressor?
Is it 120 volt only or you have a choice ?
You wire it for 240, if you have a choice
The wiring diagram is on the outside of the motor
or inside on the small cover, where the wires go to
You buy some 12/2 rubber cord & wire to the motor &
put a 240-20 amp plug on the other end
On the wall you mount a 1900 box & a cover with the
240-20 amp duplex
Aug 09, 2014 | Air Lift Air Tools & Compressors
Wiring for Honeywell H46C1166 - Dehumidistat, 24/120/240 Vac Wall-Mounted
Suggest you people READ the question before giving BS answers !!!!!!!!!!
Jul 22, 2012 | Honeywell H46C1166 - Dehumidistat,...
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
Logitech X-240 woofer
you should google it and find a woofer of the correct size with at least 8 ohms to be safe. (more ohms= less risk of fire!) good luck!
Jul 26, 2008 | Logitech X-240 Computer Speakers
They Crashed
seem static electricty issue.
unplug computer from the wall socket and hold down the power botton for 10 sec. do the same with speakers. pluge back it should work.
hope it will help..
May 30, 2008 | Logitech X-240 Computer Speakers
Wall mount Heather no heating
check the breaker is not blown. if it is reset it. if you have the electrical knowledge see if you have 240 volts at the heater.
Jan 29, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Cadet wall mount and thermostat
your wiring is all wrong. for a 240 heater a 20/20 tandem breaker will not work with a 240 heater. you need a 20 amp two pole breaker. the two wires at the heater need to be connected to the line. you probably have two black wires at the heater. one connects to the white romex which should be taped black, and the other romex black connects to the other black wire. at the panel one white goes to one side of the breaker and the black to the other. the bare ground goes to the neutral bar.
Oct 27, 2007 | Cadet Manufacturing 67507 Heater
Wiring my 240 V wall mount heater
Your question is kind of vague, but the 240v goes to the heating element, if the heater has a fan, it may be a 110v, so the white is common and should be wired as such. The heater should have a wiring diagram on it.
Oct 26, 2007 | Fahrenheat (FFH1614) Wall Mounted Panel...
Logitech X-240 Computer Speakers Logo
23 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
