Question about Sony Grand Wega 50 in. Diagonal Class 3LCD Rear Projection TV/HDTV,
I replaced thee lamp in my sony wega 3lco tv now it wont turn on and the standby light flashes 3 times. how can i fix this?
I have a sony wega television i replaced the lamp now my tv is stuck on standby the red light flashes three times
  • 51 Answers
SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Posted on Jul 10, 2008
  • 4234 Answers
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Posted on Mar 19, 2009
rylee_smith
  • 8619 Answers
SOURCE: Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 01, 2009
SOURCE: My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Posted on May 19, 2010
welcomejee
  • 10594 Answers
SOURCE: Sony Wega television has a red light flashing that
When Sony tv shows lamp light that means lamp inside tv is dead/ broken and need to be replaced.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Posted on May 27, 2010
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
I have a Sony tv KDF50WE655, the other day while I was watching tv, heard a noise and the tv went off, displying the lamp red light..I ordered and replaced the lamp. I made sure the lamp is ok and the door...
Please make sure lamp cover is fixed properly in its position after lamp replacement as it has to press a safety switch located nearby lamp cover.
3 times red blink problem is related with that lamp cover safety switch only.
Hope this will help.
Thanks.
May 27, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv will shut off and red light will flash 3 times
If its Sony KDF-42WE655 TV that goes to standby and LED blinks 3 times then check Lamp Door that seems not fixed properly.
That happens when lamp replaced in TV.
If its different model number TV, let me know exact model number.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
Jun 27, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
No sound or pix
3 times flash of standby light shows that Lamp Cover is not mounted properly after replacement of Lamp.
Please fix lamp cover properly because cover has to press protection switch in circuit.
Sep 17, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Got a sony grand wega kf-42sx300u tv. the standby indicator on the tv flashes
Im afraid my friend the lamp needs replacing (model: XL-2100E), if you have a hunt on google you will be hit with the pain of the cost... like me :(
Aug 11, 2008 | Televison & Video
SONY GRAND WEGA KDF55WF655
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand Wega 50 in. Diagonal Class 3LCD Rear Projection TV/HDTV, Logo
14 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
