If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
what brand furnace is it? is there any blinking light on the control board? is the tube going to the pressure switch blocked? there should be a tube going from the pressureswitch to the inducer motor housing take it loose from the inducer and check for obstruction there,dont blow back into the switch.
Clean the flame sensor with a green scotch brite pad. Check all ground connections from the circuit board to the furnace cabinet. Check for a proper ground to the electrical box. Make sure polarity has not been reversed.
Hi, welcome to Fixya. If you have spark ignition turn off the power and using sand cloth clean the rod(s) and hood of the spark ignition. If it is a Hot Surface Igniter (glow coil) look on the opposite end of the burners and you will see a rod protruding in to the flame. It's called a flame sensor. Clean it with the sanding cloth. If either of these works then you bought some time but should consider replacing the part fairly soon. Please report back to let us know your progress. Good luck.
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Your furnace is going into a lockout condition, cycling the power resets the circuit board and it starts over. I will need to know approximate age and model of your furnace, it sounds like you have need to clean the flame sensor rod. However i need to know what i am working with.
