Question about Gralab Model 300 Electro-Mechanical Darkroom Timer
Owner's manual tivoli TDHT1 - Gralab Model 300 Electro-Mechanical Darkroom Timer
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
Jul 13, 2017 | Tivoli Kloss Model One AM/FM Radio
The iPod connection on my Tivoli audio is broken. Do you know where I can fix it in Swedwn, Gothenburg?in sweden
Unfortunately you will have to contact the local delearship for help in this regard who can guide you for a service centre in Sweden.
Howeverf you can click this link and post your problem to the official site of Tivoli
Nov 05, 2010 | Tivoli Audio Players & Recorders
Tivoli model Satellite will not turn on. Had intermittant power issues. Moved the radio and it will no longer power on
The power control problem is easy to fix.
It can as simple as a fuse (I'm sure you check it already) or a switch that is piggy back on the volume control.
Radio Shack has a similar one HERE
Disconnect the AC outlet and open the main Tivoli unit.
Look at the back side of the volume switch and you will see a power switch piggy back onto the volume control.
You can bypass it or get the correct value Potentiometer + SPST switch.
Use an ohm meter to meter the both end of the potentiometer and if it's 10,000 ohm or 10k then just go to Radio Shack and ask for
10K-Ohm Audio Control Potentiometer with SPST Switch Model: 271-215 | Catalog #: 271-215
It's a direct replacement.
If the ohm read is other then 10K then you will need to order it for an electronic supply house.
Tivoli makes great radio.....if you want to sell it I want the first dip.
Jul 30, 2010 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli Audio Music System: CD wont eject
We've had the Tivoli Music System for 3 years. A CD became stuck in the player when I pressed the EJECT button before turning the player on. We tried turning it off and back on, unplugging it for a minute, removing the batteries and unplugging, etc. Nothing worked. I finally turned the player upside down in my lap, then turned on the CD player, and it said LOADING! Progress!!! I turned it right-side up and hit EJECT, and it worked like new. The CD loading mechanism had become bound up and simply needed a different "attitude" adjustment. Don't give up too early in attempting to fix these players on your own.
Feb 17, 2010 | Tivoli Audio® Music System Shelf System
Does the battery charge with the power off? or does it have to be on am or fm
Most units like this will not charge the battery because if the owner installs the wrong type of batteries it becomes a fire hazard.
Eric
Sep 23, 2009 | Tivoli (PAL) AM/FM Radio
Need to replace home theater subwoofer-Tivoli TDHT1 is the system
You please check the ohms with the woofer watts so that the same frequency of the woofer you can fix of different company, otherwise there will be damage of the circuit board so please use the appropriate frequency of woofer speakers.
Mar 28, 2009 | Audio Players & Recorders
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Tivoli model two - low/no sound in base unit
I have exactly the same problem but found two work arounds, either one that I am completely satisfied. 1. unplug and replug the AC.
2. I have a subwoofer, when I plug the subwoofer cable half way in, the sounds of the base speak goes back to normal (but not all the way in)
Dec 26, 2008 | Tivoli Henry Kloss Model Two FM/AM Radio
Tivoli Radio,
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Oct 21, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Tivoli Stereo Speaker
Any speaker has the potential to be used as a computer speaker. The problem you will run into is what will be used to power the speaker. Typical computer sound connections do not put out a strong enough signal to power a full sized speaker on their own. If you hooked the computer to an amplifier and then to a speaker it would work fine. If you do this, I recommend using the line out connection on the computer instead of the headphone connection.
Jul 20, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Gralab Model 300 Electro-Mechanical Darkroom Timer Logo
63 people viewed this question
Top Gralab Video Cameras Experts
Are you a Gralab Video Camera Expert? Answer questions, earn points and help others
