Question about Epson Office Equipment & Supplies
The lamp on my Epson EH-TW4400 has blown up after 862 hours on 'eco'. I replaced the lamp under warranty, reset the counter, but it stays at 0 hours. Any easy solution?
  • 17 Answers
SOURCE: Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Posted on Jul 17, 2008
SOURCE: Lamp timer reset
Found in the owners manual.
It's important to reset the Lamp timer after replacing the lamp since the Lamp timer
will trigger the warning message. This can be done in Standby mode by pressing the
following sequence within 5 sec.
RESET, Left Arrow Key, right Arrow Key, ENTER.
This is also explained in the operation manual of the Lamp.
Posted on Feb 03, 2009
  • 134 Answers
SOURCE: Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Posted on Feb 21, 2009
projdoc
  • 2237 Answers
SOURCE: NEC VT 480, replaced new lamp ,still low brightness.
if you remove the lamp, inside the lamp housing you will see a refraction (fly-eye) lens. these evenly distribute the lamp light. the one on the other side from the one you see (there are always 2 lenses) is probably burnt and needs replacing (a common problem with lcd projectors). you will have to send it in to nec. in many of their projectors, both lenses are in one assembly.
Posted on Sep 11, 2009
BILLatNASA
  • 3 Answers
SOURCE: How do I reset the lamp hours on an epson
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Posted on Sep 20, 2010
Epson 5010 can't open
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Mar 05, 2014 | Epson ELPLP69 - V13H010L69 Projector...
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
wheel,
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
How to reset lamp timer on Toshiba TDP-T45
Reset the LAMP COUNTER HOURS:
1. Turn off the projector and unplug the power cord.
2. Press and hold down the three buttons at a time (ON/STANDBY) (MENU) and (INPUT) and plug in power cord.
3.The lamp hours counter will automatically turn to zero
4. Now you press POWER BUTTON and after warm up you check lamp operation counter in the STATUS display it should be "0"
Dec 27, 2010 | Office Equipment & Supplies
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
How can i reset the lamp of epson emp 7250 projector
Mar 23, 2010 | Epson Office Equipment & Supplies
I can't reset the hour counter and I have no sound
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
As for sound, more info is required.
I hope that helps.
Dec 26, 2009 | Panasonic PT-52LCX66 Projection Television
How do I reset the lamp hours on an epson powerlite 7250 projector after replacing the bulb?
Dec 05, 2009 | Epson Office Equipment & Supplies
Indicator lights on, no function, no fan, no lamp
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Oct 11, 2008 | Panasonic PT-LB20U Multimedia Projector
Lamp
Did you reset you lamp hours when you reinstalled you new lamp?
Sep 05, 2008 | Office Equipment & Supplies
Optima H30 warning
OK, found the solution on the net, you have to use the buttons on the projector instead of the remote to access the menu item.
Aug 25, 2008 | Optoma H30 Multimedia Projector
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
