Question about Air Tools & Compressors
Sullair LS10 25HP
Oil is foaming up. changed oil several times. any suggestions??
5 Suggested Answers
  • 1388 Answers
SOURCE: overheating? burnt oil smell
There is a seal between the compressor and the motor that in failed condition will leak oil into motor windings causing burnt oil smell. Some hitachi compressors suffered from failed valves or head gasket causing extra heat but not oil smell. These compressors also have a thermobreaker built into the windings that when failed will prevent motor from starting or would start and run for only a few moments then open. This part is not replaceable. enjoy
Posted on Nov 29, 2008
ollie reece
  • 1167 Answers
SOURCE: We have a Sullair 100 GPQ lubricant recommendation
hi mate ask the manufacturers as different compressor take different oils like im a compressed air engineer and i use rcr 32 and rcr 46 but i have never had to work on a sullair as there not common in our area
Posted on Aug 08, 2009
  • 142 Answers
SOURCE: When I fill with oil and turn on the oil foams up
sounds like toooo much oil, make sure to only have it filled to the full mark on the dipstick or the oil level line in the sight glass
Posted on Feb 10, 2010
  • 10 Answers
SOURCE: I have a 450 sullair portable air compressor that
Along with the oil air separators, there is a filter in the oil reservoir tank that needs to be changed every six months. You should contact a qualified air compressor shop for regular service. If the filter is not installed correctly, injury or death may occur. Pool tile cleaning uses the same compressors.
Posted on Jun 17, 2011
Sullair 185 has oil in air discharge line
The rings of the compressor piston are not sealing.
Dec 08, 2016 | Air Tools & Compressors
My oil is foaming up. Changed oil and cleaned well but still foaming up. I am using the same oil as always and never happened before. {This happened after changing the thermalcoupling.
Hi there.
Oil foaming is caused by water, saturated oil itself and/ or overloaded product. Make sure your fryer does not have any of the things mentioned above.
Try performing tank boil out to ensure the cleanliness of the fry tank.
Regards.
Oct 08, 2013 | DCS Kitchen Appliances - Others
Type of d a torque fluid used in sullair 185Q air compressor
contact sullair for this as the correct oil is essential for good performance. You may find the information on the web under sullair compressors.
Jul 21, 2013 | Cars & Trucks
Sullair compressor
check condition of air filters and dryer filters.
May 16, 2013 | Sullair 350 Air Compressor; Sullair...
Ticking in the motor
Sounds like you have a lifter that is sticking. Purchase a can of Seafoam Motor Treatment at Advance Auto Parts, Walmart, and many other suppliers. I have used this product many times and it is fantastic. This is not a motor treatment such as some of the others you see advertised to improve mileage or stop oil burning. This is a legit product that many mechanics trust. To clean lifters, add 1½ oz. Sea Foam to each quart of oil. Sea Foam will slowly re-liquefy the old oil varnish residue that builds up on lifters and prevents them from functioning normally. This process can be done as part of a pre service cleaning by adding the Sea Foam to the oil at least 30 miles before the next oil change interval. OR it can be done as a preventative maintenance process without changing the oil. You can leave Sea Foam in the oil indefinitely as long as the oil is clean. The addition of a high-detergent oil like Sea Foam may cause the oil to become dirty faster than normal as buildup oil residue and contamination are cleaned. Check the oil at regular intervals and when it gets dirty, change it. http://www.seafoamsales.com/how-to-use-sea-foam-motor-treatment.html
May 21, 2010 | 2000 GMC Jimmy
Sullair 185 screw compressor
The sullair 185 has a low oil pressure override button that you have to hold in while starting. after the oil pressure builds up(takes about ten seconds) you can release the button and the machine should continue to run.
Feb 19, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
My 2004 nissan sentra se-r spec v has a knocking noise...it definetly sounds like its on the top...can the valves be adjusted or what do you suggest concerning this problem?
there are several things that can lead to this. first check oil is there any water/antifreeze or white foam in it? if yes engine needs to be rebuilt/replaced. 2 check anti freeze/coolant is there any oil in it? is oil level really low or really black and thick? can be a head gasket has blown or lack of oil or oil change and wrist pins or bearings are ruined from lack of maintenance. best bet is to take to several garages and have them diagnose problems. get 3-4 opinions and go from there. was engine used to race and with manual transmission it could have been over revved and blew bearings.
Oct 30, 2009 | 2004 Nissan Sentra
Jul 30, 2009 | Air Tools & Compressors
V8 engine
If your oil is not over full its not getting any water in it..Sometimes oil gets moisture in it and it collects on the cap or if its a cheap oil it foams up a little.Nothing to worry about as long as your oil level stays the same..Don't worry be happy.Hope this helps you and have a great night..
Apr 02, 2009 | 2000 Jeep Grand Cherokee
Air Tools & Compressors Logo
56 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
