Question about Welding Tools
Power fist mig welder continuosly feeds
Turn welder on wire keeps feeding, pull trigger it stops
  • 5 Answers
SOURCE: northern tool mig welder,120 volt with gas.The
This welder is made in China. I have one and it works fine. Parts and service are available from northern tool. 1-800 # is on the book. FYI this 135 gas no gas looks exactly like the Lincoln SP135 and Lincoln workmate 135. GOTO the lincoln site and bring up the manual. It is a free download and is a much better manual than the one it came with. I agree with the previous post. Put a continuity test on the 2 wires that come from the trigger. there is a wire diagram in the book that came with it. Hope this helps.
Paul
Posted on Apr 28, 2009
SOURCE: Toolex 140 mig welder, wont feed wire.
You may have the scew settint your wire tension set to tight. Try loosening the tension and if that doesnt work check the eletrical wire that supplies the power to the roller and make sure it hasnt become disconected.
Posted on Jun 28, 2009
luxur4
  • 92 Answers
SOURCE: solar welder 2175 wire keeps feeding wont stop
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
Posted on Jan 26, 2010
SOURCE: clicking noise when trigger is pulled
Sounds like a switch problem to me?
Posted on Feb 20, 2010
  • 6 Answers
SOURCE: Wire feed does not stop. Not the trigger.
you have a problen with the electronic circuit.
Where are you?. Perhaps I can help you.
Posted on Aug 16, 2010
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
I have a kende mig 105 gasless welder,but the wire isn't getting fed through on the feed wheel,tried different welding wire and also turned the wheel,tried tightening the wheel,slackening it as well,i
Here's a few things you can check:
When gun trigger is pulled, do the drive wheels turn? If they aren't, pull the trigger again; do you hear anything within the machine (contactors closing, gas solinouds opening, any clicking, etc.) that would indicate the trigger circuit is functional?
If the drive wheels are turning, but wire isn't being pushed thru the mig gun, check for proper drive roll vs. wire size. If that is correct, check gun liner for obstructions. Flux cored wire tends to stop up a wire liner fairly quickly.
Dec 21, 2014 | Welding Tools
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
My wire feed wheel on my lincon sp130 mig welder has ceased to turn. How do I trouble shoot if it is a burned out motor or something else?
Check the voltage at the wire feed motor while the trigger is pulled. If there's no voltage, it's pretty safe that it's not the drive motor.
Also, with the unit unplugged, check the big power (stud) diodes for shorts.
I had a wire feed motor stop because 2 of the big diodes were shorted.
Apr 20, 2010 | Welding Tools
Solar welder 2175 wire keeps feeding wont stop doesnot arc until trigger is pulled
Ken
Dec 14, 2009 | Welding Tools
Wire doesn't feed
Either the trigger mechanism in the gun is bad, the servo that turns the feed wheel is bad, or you have too much tension on the adjustable tensioner knob. Take the wire out of the feed wheel, plug unit in and see if you can get the wheel to turn. If not, it is the trigger or the servo. If it turns, the tensioner was too tight.
Jul 10, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Jun 26, 2009 | Welding Tools
Ck the feed roller contact relay
Jun 02, 2009 | Welding Tools
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
