Question about Garden
How do I adjust the electric clutch model # 180505 on my Craftsman Riding Lawnmower model # 917 274641?
How do I adjust the electric clutch on my Craftsman riding mower.
SOURCE: Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
Posted on Mar 24, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
Lt1000 riding lawnmower. Why is shifting difficult?
your clutch linkage can be adjusted a little bit,or you can fill the rear with gear lube
Jul 11, 2015 | Craftsman Garden
How do you adjust the electric clutch 180505
depends if it's adjustable or not remove mower deck and look at motor shaft you'll see clutch (it's got a wire going to it) if three springs are held in with rivets then it's not adjustable you'll need to relpace it if it's got three phillips head screws then in a alternate pattern try tighting each one half a turn and test it , if screws bottom out replace clutch
Nov 21, 2013 | Craftsman Garden
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman lawnmower dies when i let out on the clutch
make sure your not in reverse with the blades on. if so turn the key left to mow in reverse mode. else check pullies.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
INSTALLING CLUTCH CABLE ON CRAFTSMAN
the proper threading of cable clutch for 38 in. craftsman riding lawnmower model 271150
Mar 29, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Jun 23, 2009 | Craftsman Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
