Question about Whirlpool Refrigerators
Programming control board for whirpool gold model gx5fhtxvy
I have the control board but i dont not how to program the control board please help
SOURCE: RCA D770 dont know how to program--lost manual
Check this link to Wiki,
http://wiki.answers.com/Q/How_do_you_program_an_RCA_d770_universal_remote_if_you_don't_have_a_code_search_button
http://download.ethomson.com/english/RCA/ACCESSORIES/IB/D770.pdf
I had trouble with the ethompson link
Turn on device.
Press and hold the button for device you want to program ( TV etc),
press the on/off button and hold until the LED turns on, and then release both buttons.
Then, point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing. If the device does not turn off, then continue to press play and wait the required interval (for a maximum of 20 times) until the device turns off.
When the device turns off, stop pressing play.
Press REVERSE, wait two seconds and continue doing this until the device turns back on.
To finish programming, press and hold STOP until the LED turns off.
Posted on Aug 18, 2008
  • 44 Answers
SOURCE: i have a rca312w control and the codes to program my sylvania tv
Try these codes 0054 or 0030
How To Program Your Remote Control
  1. Turn device to be programed on.
  2. On the remote control, press a device key one (e.g., AUD, VCR, TV, or CBL). Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
  3. Locate the four-digit code found in the list below that corrisponds with the device you are programming then enter that four-digit code. If performed correctly, the selected mode key will blink twice.
    (NOTE:If the selected mode key emits a long blink, the code is invalid. Repeat steps 2 and 3 and try entering the same code again.)
  4. Aim the remote control at the device ad press POWER once. The device should trun off. If it does not, repeat steps 2 and 3, tryin each code for you brand until you find one that works. If it still does not work, try searching for the code.
  5. Repeat steps 1 through 4 for each device you want the remote control to control.
Posted on Nov 11, 2008
stuarttx
  • 15 Answers
SOURCE: program remote control for mazda mpv 2002
Courtesy of: forums.mazdaworld.org
Try this, it works on several 2002 models:
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done
Posted on Feb 21, 2009
6ylucy
  • 742 Answers
SOURCE: I have an Acoustic Solutions TV model LCDWDVD19FB
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Posted on Jun 18, 2010
GX5FHTXVY Energy Star Gold 24.8 Cu. Ft. French Door Bottom-F
I am not a mechanic, but I do like to fiddle around with problems, to sort of i give my hand a 'try' at it. My next venture is to unplug the freezer, let it stand for a few hours, and re-plug it back on and see what happens. You never know. So, let's give it a go. That's it for now for me.
Nov 21, 2013 | Whirlpool GX5FHTXVY Energy Star Gold 24.8...
The refrigerator isn't getting cold.... It is about 2 years old
IF the freezer is still cold, you have an air flow problem. This is usually a defroster problem or the fan in the freezer has quit.
Aug 27, 2013 | Whirlpool GX5FHTXVY Energy Star Gold 24.8...
Whirpool ADP 5550. Will only rinse. Does not
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 17, 2011 | Whirlpool Dishwashers
I am looking for software to program Uniden SPU480K Handie Talkies
http://download.cnet.com/scancat-gold/3000-2130_4-10041190.html Scancat-Gold for Windows is an 'All in One' computer program to take control of your Police Scanner or Shortwave Receiver. Scancat supports all radios within one program. We support most popular manufacturer's radios such as: AOR, ICOM, KENWOOD, JRC, UNIDEN, YAESU RADIO SHACK. New trunk tracking support has recently been added for models such as the BC780, BC245, BC895 Uniden and PRO2052 Radio Shack. Hope thie helps
Aug 04, 2011 | Computers & Internet
Hi Gurus - we have a Whirpool Gold Quiet Partner III whose control panel is dead. Pressing Air Dry doesn't seem to work. Looks ok at the fuse box. Should we get an electrician in, or an appliance...
On a lot of whirlpool models their is a fuse on the control board that is wired directly to the board if it goes out the machine will be dead exactly as your experiencing,i would call a appliance tech and if it something ya think ya can repair,reply back with model# and ill give ya part #
Hope this helped and if it did please give me 4 thumbs up
Gene
Jul 28, 2011 | Dishwashers
Hi, I am getting an error reading on my whirpool gold stove it reads EO -F2- do you have any clues to what my be my problem. Thank you in advance for your suggestion
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 20, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
How do you turn off the control lock?
Directions are under rightmost button. Please contact me if you need further help or leave feedback. Thanks for letting me help you!
Dec 01, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I need direccions to program mi remot control
I JUST LOST MY MANUAL AND I NEED THE CODE AND THE DIRECTION HOW TO PROGRAMMING MY REMOTE CONTROL.MY TV IS PANASONIC.CAN YOU HELP ME, PLEASE.
MY EMAIL IS :ruthfernandes@rocketmail.com.I APPRECIATE YOUR HELP.THANKS.
Nov 13, 2008 | RCA 3-Device Universal Remote with...
Whirpool Gold Acubake gas stove model GW395LEPB02 purchased in Oct 2006.When I am baking on 350 the oven jumps to 500 and smokes is everywhere. The number E2F3 shows up on the control board. What is the...
This error indicates the Oven temperature is too high,
You will need to replace the Oven temperature sensor (RTD).
This part can usually be replaced from inside the oven.
Jun 22, 2008 | Whirlpool Kitchen Ranges
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
