My machine is beko EV 6800 its my problem is when the programme was finish i cant open the door of the machine the program indicator keeps on blinking until now what will i do.
Its new just that i cant open when the program was finish help me please
SOURCE: Beko WMA 1715S
try unplugging and let it reset itself
Posted on Apr 03, 2008
SOURCE: programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Posted on May 23, 2008
SOURCE: Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Posted on Jan 03, 2010
rylee_smith
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
SOURCE: My beko washing machine smells of burning
i need a motor circuit to test the motor of a defy automaid it does not spin fast
Posted on Jan 23, 2011
CORRECT LICENSE KEY NUMBERS WILL NOT OPEN EITHER PREMIUM PROGRAM.
When you have problems with registration keys always contact the program owner ( Microsoft, Adobe etc) and explain the problem
they normally will send a e mail with a link to a new number
Apr 12, 2015 | Computers & Internet
BEKO 6108 XE door does not lock and machine won't do anything
might be a knackerd interlock on the door...
cheers
Mar 04, 2015 | Beko Washing Machines
How do I stop machine mid program to change to another program?
Go to stop or a program that ir a reset mode. Cheak the make and model and look in you manual that came with the machine. Normally there is a stop mode.
Nov 09, 2014 | Beko Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
I would like to unblock all my websites please especially facebook as their has been a problem with our computer we cant get on facebook
Hello jademayes_91, I will guide you through the steps to "Unblock" Websites. First, from the Desktop, click on the Start Button,"paul7of9_24.png select the Control Panel in the [Right] short-cut menu. Next, once the window open click on thepaul7of9_25.png "Allow a program through Windows Firewall, in the "Security" categorypaul7of9_26.png. The next window that opens will be the [Windows Firewall Settings], select the "Exceptions" button. Once the window open, you can [Check / Un-check Programs] to "allow or block." Your focus or area of concern will be the "Add a Program" button at the bottom of the window.paul7of9_27.png You can use the [Browse Button], if you don't see the programs that you want to "Unblock." To finish: Click OK, to complete all changes, and you may also be require to "restart" the computer. "Please take the time to give a response to the help, by clicking on the "Thumbs Up," this is my reward for the help provided. Thanks for using Fix' Ya, and I hope all goes well!" paul7of9
Dec 09, 2010 | Computers & Internet
Beeping sound when cycle is finished just started after 8 years. how do I turn it off?
Welcome to FixYa.
I think can answer your question..."beeping sound when cycle is finished just started after 8 years. how do I turn it off?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
? If the display blinks with a "0", you will hear
no signal (indicates OFF).
? If the display blinks with a "1", you will hear a
LOW volume signal.
? If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Nov 06, 2010 | Bosch SHU9915UC Dishwasher
How to cancel drying?
Please press the reset switch which should be on the control panel or next to the loading door
Nov 14, 2009 | Indesit WA 115 Front Load Washer
I was uninstall and install my yahoo messenger onto my computer but i cant open it,but i can open my mail,,what should i do?
Click Start button on taskbar click Run type chkdsk ....wait until it finish....Now try to run Yahoo messenger...
If that doesn't help clean your registry and re-install yahoo messenger....or uninstall yahoo messenger and delete the Yahoo! from C:/Program files/ and Install again new yahoo messenger from http://messenger.yahoo.com/download/winbeta
I think it will help you....Thanks for being with Fixya...Good luck
Nov 06, 2009 | Yahoo Messenger
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
