Question about Konica Minolta Bizhub c203 Copier
When trying to scan to email from Konica Minolta C203 we get an error message "From Address not set, unable to Transmit, please specify From Address" any ideas.
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Posted on Mar 09, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Konica Minolta Scan to email/Ftp
Nope.
A scan accerator kit may be rquired.
Posted on Sep 09, 2008
  • 4 Answers
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Posted on Oct 19, 2008
herminio_hal
  • 210 Answers
SOURCE: I need to scan to email using the c353 konica
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Posted on Aug 11, 2009
After upgrading to windows 10, unable to scan doc from Konica C203 to PC
To help you troubleshoot the issue about unable to scan but able to print, it is recommended to try uninstalling the previous software and driver and re-install Konica Minolta BizHub C203 printer software and drivers from the link given below:
http://www.biz.konicaminolta.com/download/driver.html
If issue persists, you can find the troubleshooting link and check if that helps to resolve the issue:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C203&page=1
If issue persists, it is recommended to contact Konica Minolta bizhub for further assistance:
GuruAid.com
Jun 13, 2016 | Konica Minolta bizhub Office Equipment &...
Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
How do we properly shake the image unit of the Konica Minolta bizhub c203 to clear error message C-2558?
ugh sorry replace the toner hopper and all of the componets if a new iu dosnt fix the problem
Aug 18, 2014 | Konica Minolta Bizhub c203 Copier
What software do i need to scan through a PC?
GO THOUGH WEB BROWSER ONLY THING YOU HAVE TO DO SET UP IP ADDRESS, DOWNLOAD DRIVER FROM KONICA/MINOLTA FOR BIZHUB C203 THEN WEB BROWSE TO SET UP SCANNER SOFTWARE ALREADY THERE.
Oct 21, 2010 | Konica Minolta Bizhub c203 Copier
Server connection error when scanning
have you set up your scan Email account with you page Scope disk with the copier. is the server set up for scan to email. Also check the konicaminolta web site for scan operator manual. Down load the scan programs
Mar 24, 2010 | Konica Minolta Bizhub c203 Copier
Email result EA3227
IP Scanner operations
Error Code Cause Remedy
EAXXXX ImageReceiver was not started.
Start ImageReceiver.
The IP address of the recipient
is not specified correctly in the
dialog box that appears after
clicking “Receive Settings”,
then “Connection Filter”.
Click “Receive Settings”, then “Connection
Filter”, specify the correct IP
address, and then restart ImageReceiver.
ImageReceiver is not operating
correctly.
Restart the computer.
Re-install IP Scanner.
Check the TCP/IP settings on the computer.
The LAN cable is not connected.
Check that the LAN cable is correctly
connected.
The network settings on the
computer are not specified
correctly.
The network load on the recipient’s
computer is too high.
Check that large e-mail messages are
not being received at the recipient’s
computer and that large files are not
being downloaded from the Web.
Too much data is being sent. If a high scanning resolution has been
specified, reduce the resolution or decrease
the number of pages scanned
at one time, and then scan the document
again.
Access is blocked by the setting
specified for the computer’s
firewall (Windows
firewall) for the Internet connection.
Change the setting specified for the
computer’s firewall (Windows firewall)
for the Internet connection according
to the instructions from your network
administrator.
Oct 07, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
CF2002 Trouble Scanning to Email
scan to email can only be setup to work on a internal email server if the email server is external it will not work. also make sure you input the admin email address and the from email address when configuing the machine
May 14, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta 250 Bizhub scanning Operations
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub c203 Copier Logo
47 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
