Question about BenQ W100 DLP Projector
Benq w100 flickering - BenQ W100 DLP Projector
W100 not working when turned on the 3 leds just flash
Hello Steve, hi, the power supply detected an overload, thats the reason on the 3 LED light. most likely your DLP has power supply problems. I suggest you bring it to a DLP dealer and have it checked.
Jan 06, 2011 | BenQ W100 DLP Projector
My BenQ G2220HD Monitor flickers. I've tried my level best to solve this problem but could not get rid of the flickering.
Try connecting it to a different laptop/desktop, to see if the flickering "follows" the monitor. If not, then the video-card in your computer is the problem -- try connecting another monitor to your computer, to see if the flickering still happens.
Sep 02, 2010 | BenQ G2220HD Monitor
Hello my benq w100 shut down because of I ignored the lamp warning now i chanced the lamp but its not working need to know what to do resume something Christer from Sweden
HI
PLEASE RESET THE LAMP & TRY .
LAMP RESET - PRESS EXIT BUTTON FOR 3 SECOND & SEE THE DISPLAY RIGHT SIDE AT BOTTOM .READ THE INSTRUCTION & WHICH BUTTON TO BE ENTER
M.R.CORPORATION MUMBAI -DUBAI
Aug 27, 2010 | Office Equipment & Supplies
My niece squeezed an object into my Benq DLP W100 projector and now it is manfunctioning. I think it would be a simple solution if I could only open the unit. How to do that however. I removed all the...
I got the same projector and have had to take it apart a few times, they are not to hard to open
There are 5 (not inc the projector cover screw) screws to remove from the bottom of the projector (A long neck philps screw driver will be needed). Once these are removed The top will be loose apart from catching midle of the front and at the back, This is down to the top being clipped in the middle.
Remove the grey panel round the connectors, one sreew and the 2 plug fixing nuts around the DVI Port. Once these are removed pull the panel away from the projector, pulling from the midle of the panel as its cliped to the side. Once remove lift the top of the projector roateing it around the front
Hope this helps
May 09, 2010 | BenQ W100 DLP Projector
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Monitor Flickering
If you have some electrical equipments like CVT, UPS near to your monitor, please put them away. If the flickering is due to the maganetic interfearence then it will solve your flickering of screen. and even after this if you are not able to use your monitor buttun then please call your technical expert b.coz your monitor may got some physical problem.
Thanks
Iqbal
Mar 08, 2008 | BenQ FP567s 15" LCD Monitor
BenQ W100 DLP Projector Logo
18 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
