Question about Dymo LabelPOINT 200 Thermal Printer
Dymo 450 twin turbo is not printing in the correct area on the label
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
SOURCE: Twin Turbo pushing out a lot of unprinted labels
The people at Dymo's tech support (1-203-588-2500), told me that the problem is a dirty sensor. If you open the front face of the machine (the part with the words "Dymo Labelwriter Twin Turbo" on it), on the inside (top) you will see the black rollers and a peice that is on top of the roller that is the same color as the face you just removed. That peice can be lifted and underneath it you will see an orange transparent peice. This is the sensor. To clean it, you can either use the cleaner sheets that came with the printer or a business card. You will need to put enough alcohol to make the card damp (but not soaked) and run it through as if it were a label 10 times. This should clean your sensor so that it is able to clearly tell when to stop feeding.
It sounds complicated, but its really not. I hope this helps somebody!!!
Posted on Jun 04, 2009
SOURCE: OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Posted on Jul 09, 2009
  • 14 Answers
SOURCE: Dymo label writer 400 turbo will not print
Uninstall the software and disconnect the printer from your PC. Then reinstall version 8 of the Dymo Software (without the printer connected) and connect the printer when prompted by the software.
Make sure you are using version 8 of the dymo label software - it is compatible with Windows 7.
Posted on May 06, 2010
  • 3 Answers
SOURCE: My Dymo Labelwriter 450 turbo feeds out 4 labels
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Posted on Jan 26, 2011
My dymo 450 turbo prints only 1 label even i order to print 10 labels. I use mac(10.11.5) and dymo label(8.5.3). updated last version.
Double check that your using correct printer driver.
Completely remove restart computer with printer discontente,then reinstall the printer.
Jun 29, 2016 | Dymo LabelWriter 400 Turbo Thermal Printer
How to disable DYMO label roll sensor in DYMO 450 turbo
The sensor cannot be disabled. DYMO printers (including the 450 series) are hard-wired to only work properly with genuine DYMO labels.
^CM
Mar 14, 2014 | Dymo LabelWriter 450 Turbo USB Label...
Won't print from another mac as can't find printer
You can try going to System Preferences and pressing Resume to make sure the printers are not off line. Otherwise, please contact us (see dymo.com for numbers).
^CM
Dec 26, 2013 | Dymo LabelWriter 1752266 450 Twin Turbo...
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
When adding the Dymo labelwriter 450 turbo to Windows 7 machines, the installation completes fine. When attempting to print, an error shows up in the device manager that says Access Denied for the print...
i HAVE LABEL WRITER 450 TWIN TURBO AND I CAN NOT PRINT RETURN ADDRESS LABELS. i HAVE UNINSTALLED AND INSTALLED AGAIN THAT DOESN'T WORK THE RETURN ADDRESS LABEL IS THERE IT WON'T LET ME TYPE ANYTHING IN THE SPACE PROVIDED IT WAS WORKING FINE THEN THE NEXT DAY IT WAS NOT
THANK YOU
Aug 19, 2011 | Dymo LabelWriter Thermal Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
Hope this helps.
Jun 17, 2009 | Dymo LabelWriter Thermal Printer
Not printing
I have installed the Dymo LabelWriter Twin Turbo and it iwll not print my labels. Any suggestions?
Aug 15, 2008 | Dymo LetraTAG Thermal Label Printer
Dymo LabelPOINT 200 Thermal Printer Logo
13 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
