Question about Baseball & Softball
How to do the string inside the dreamcatcher?
String is inside c430 trimmer and won't bump out.
then take it apart and get the string out thru the hole(s) again
Aug 09, 2016 | Garden
How do I get the trimmer head open?
Turn the knob in the middle of the head anti clockwise and the string reel should come out.
Aug 21, 2015 | Garden
Why won't the string advance?
many times it is because the string has welded itself inside the head . and we have to use pliers to help it get loose again .
Jun 17, 2015 | Echo New String Trimmer SRM-225 2 Stroke...
Early in the games there is a part where you must place an arrow in Eros's bow. The game will not let me pull the bows string back to insert the arrow. It keeps telling me this is what I have to do but...
Best qcups
The following passage was taken from the site: http://www.gamezebo.com/games/cleopatra-riddle-tomb/walkthrough:
"Take the broken arrow (bad luck) or Cretan arrow (good luck). Return to the statue of Eros
without the arrow near the pyramid. Operate the bow and the Sagittarius icon on the pyramid
will extend. If the arrow is broken (bad luck only), open the inventory, disassemble the
broken arrow and then combine the arrow tip, arrow feathers, mended stick and pot of bitumen
to assemble the arrow. Use the arrow on the bow. Operate the bow once and it will move down
to the middle position.
Half turn and push the sign of Sagittarius on the pyramid to make Eros shoot the arrow:
It hits a point on the wall and opens a secret door. Move forward one screen. Examine the
door and then move forward one screen to Akkad's workshop."
Go to this site if you want to read more, or do a Google search using the name of the game and the word "walkthrough" to find multiple sites which could be of help.
Best of luck. From: 11407336.
Sep 06, 2011 | DreamCatcher Interactive Cleopatra Riddle...
I can't get Beyond Atlantis to install under Windows 7
there are some games that are made from an older time that just wont work no matter how new you buy it. if the game was made before 2004 then games maybe wont work. but you can probably buy a newer version of the game from the website .. thats a dreamcatcher game yes? then got to there web site and try first downloading a patch, if that does not work. you will have to buy a new copy.
Sep 24, 2010 | DreamCatcher Interactive Beyond Atlantis...
Replace pull string (how to put string on after taking cover off)
Basically, pull the string through the winding hole and knot it off insuring no more than .25" tail on the knot and pull tight. :)
Jul 22, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Trying to uninstall Time to Ride version 1.00.000-- Error Code 5001 comes up. Any thoughts? Thanks...
DOWNLOAD YOUR UNINSTALLER 2010 AND DOUBLE CLIC ON THE NAME OF THE SOFTWARE YOU WANT TO REMOVE
GET IT FROM HERE
http://www.ursoftware.com/
DON'T FORGET TO RATE ^^
Jul 02, 2010 | DreamCatcher Interactive DREAMCATCHER...
It says os not supported after download I have Windows Vista
if it says os not supported that means that the game does not support your Operating Version.
It is most likely a version for Windows XP.
If you downloaded the game try to locate another installation file for Windows Vista.
Hope it helped.
Nov 19, 2009 | DreamCatcher Interactive DREAMCATCHER...
I have an old DreamCatcher game Beyond Time - When trying to run it on Windows XP, I lose the cursor and am stuck - How can I fix this
I have a similar problem and found this link which gives a work-around
http://home.earthlink.net/~infernofilecabinet1/XpSetUpWalkthroughsA_E/Beyond_Time.htm
Scroll down until you get to the images from the game.
Sep 08, 2009 | DreamCatcher Interactive Video Game...
Baseball & Softball Logo
719 people viewed this question
Top Baseball & Softball Experts
NOEL
NOEL
Thomas Perkins
Thomas Perkins
Are you a Baseball and Softball Expert? Answer questions, earn points and help others
