Question about VIA LCD Keyboard Drawer:1U 19" Rack LCD Keyboard USB KVM Drawer w/ optional Touch Pad (RKP119eU)&Trackba... Monitor
LDS410D-1P winmate monitor flashes on and off no display shows up
Model LDS410D-1P
Pryon computer problems
Maybe your software system is broken.
May 09, 2013 | Welch Allyn Model 620411-1p - Pryon Co2...
Display are not showing cleanless
Try connecting an external monitor to the computer and see if it displays better. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your video card inside the computer is good, but your lcd screen is bad. If the Borrowed monitor displays the same way with problems, then your video card inside the computer is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
Jun 09, 2012 | Lenovo G555 Laptop
On acer aspire5755g lcd flash lines will appear and disappear when clicking on display
Sounds like your lcd is going bad. Try tapping the lcd on the back of the lid and see if the lines flash or appear. Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the flash lines then the video card inside the computer is good, but your original lcd screen is bad. If the Borrowed monitor displays the flash lines like your lcd screen then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Computers & Internet
L no display
If it seems like it booted up, you hear fans running, hard drive spinning, lights, (except the display is black) then try the steps below.
For a laptop:
For a Desktop:
Try using another monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the display then your original monitor is bad. If the Borrowed monitor does not show on the display then you Video Card is bad.
May 16, 2012 | Computers & Internet
No screen
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 29, 2012 | Acer Computers & Internet
Display problem
What's the problem with the display?
Nothing shows on the screen?
No DisplayShine a flashlight on the dark screen to see if youbarely see the icons on the desktop. If so, then the LCD Inverter isbad.
Apr 24, 2012 | HP Compaq nc6230 Notebook
My laptop not showing anything after switchng on
So, is it powering on and sounds like it's booting up but there is nothing on the display screen? Or is it just not powering on at all?
I will assume it is powering on and booting up, but you don't see anything on the lcd screen.
Mar 31, 2012 | Computers & Internet
CRA108: I can not set the time. I hold in the time button down while pushing the hour and/or minute button but nothing happens. The clock actual is displaying a time that is not proper. It currently...
My Coby CRA108 starting doing this after 6 months of use. Although I described the display as 1P:C8 since there is no key to properly display the character (hybrid of a G & C). I've left it unplugged and changed the backup battery with hopes it would reset. No luck so far. Anyone have success???
Jan 07, 2011 | Coby CRA108 Clock Radio
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
VIA LCD Keyboard Drawer:1U 19" Rack LCD Keyboard USB KVM Drawer w/ optional Touch Pad (RKP119eU)&Trackba... Monitor Logo
19 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
