Question about Reliable Dreamstitcher 787 Portable 2/3/4 Thread Overlock Machine
3ooo series where can we get parts for this machine as two tension springs are brocken and it keeps breaking needles.we are in new zealand
    Top Expert:
  • 41,853 Answers
Maybe Reliable can provide parts information and a source.
Posted on Nov 22, 2013
Needle only moves a little and then beeps saying needle up when the peddle is pushed. Machine will not run.
Good day Po!!!
Sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble; >Do this;
1.Top tension to tight >loosen tension 1 turn
2.Machine improperly threaded >check threading
3.Thread twisted on guide post > "
4.Thread twisted out of tension > "
5.Take up spring bent or broken >Check action of spring
6.Thread jumped off pull off finger >Check threading
7.Needle bent or burred >new needle
8.Bad cone of thread >try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tension spring to tight >Loosen tension slightly
2.Bobbin threaded wrong >check threading
3.Bobbin wound to tight or uneven >try new bobbin
4.lint or thread on bobbin case >clean inside case
5.Lint or thread inside hook >clean inside hook
6.Bobbin case nicked bent or burred >check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred >change
2.Needle set in crooked >Check
3.Thread jumped off take up spring >check threading
4.Thread jumped off pull off finger >check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth >Tighten bobbin tension
or loosen top tension.
2.forming loops on bottom of cloth >Tighten top tension
3.Bobbin placed in case incorrectly >remove and replace
4.Bobbin thread slipped from under >check threading of
tension >bobbin case
5.Lint or thread in top tension >clean between tension discs
Please just add a comment if you did not solve your problem by doing these procedures.
If this solution helps you please do not forget to testify and rate me...Thank you so much for using fixya!!
Jul 08, 2011 | Husqvarna Viking 1
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
My thread keeps breaking ON TOP on my Tiny Tailor. It is purchased NEW from a Store. Ido not know if it is the machine or me. I am not a beginner,just cannot get it going it is s singer
I would check to make sure your tension isnt tightened all the way down or not catching on anything, i know that slowing down the machine helps combating thread breaks. One more thing you can try even tho machine is new is to take off tension nobs and springs and turn over the felt pad underneath and rethread machine. Making sure needle is inserted properly, if in back wards it can cause thread breaks as well as needles sometimes burrs in needles (even new needles) will shred your thread and cause breaks. Hope one of thease suggestions will be of assistance
Apr 07, 2010 | Singer 3116 Simple
Reliable Dreamstitcher 787 Portable 2/3/4 Thread Overlock Machine Logo
41 people viewed this question
Top Reliable Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Reliable Tool and Hardware - Other Expert? Answer questions, earn points and help others
