Question about Whirlpool 24 in. DU910PFG Built-in Dishwasher
Water doesn't drain
The water never drains from the machine, making the dishwasher unable to clean. It makes the proper sounds (the dishwasher) but no water leaves the unit (I don't hear a draning noise in my pipes). I thought there must be something clogging the drainiage holes, but I cannot find a way to access them to see. Some drain cleaner did NOT help at all.
SOURCE:
Joe_Rex
  • 114 Answers
SOURCE: dishwasher dose not drane
YOU CAN TRY REMOVING THE LOWER RACK AND LIFT OFF THE SPRAYER. THE DRAINAGE WHOLE IS USUALLY VISABLE. YOU CAN FLUSH OUT THE DRAIN TO SEE IF THAT DOES IT. THERE SHOULD BE NO STANDING WATER IN THE BOTTOM OF YOUR DISH WASHER AFTER WASH CYCLE AND DRY CYCLE. HOPE I COULD HELP.
Posted on May 02, 2007
SOURCE: whirlpool dishwasher
I had the exact same problem with my Whirlpool Quiet Partner IV. I removed the lower arm, and a couple of components below that, and got to the filter/grinder (that thing that chops up and filters the recirculated water before it goes to the pump that feeds the arms). The filter was completely clogged. I used a knife to scrap away the foodstuffs, put everything back together and all worked excellent. Just goes to show you that you should rinse your plates before to place them in the dishwasher.
Posted on May 13, 2007
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
elhomspam
  • 58 Answers
SOURCE: Whirlpool Dishwasher DU850DWGX1 won't completely drain
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
Posted on May 02, 2008
  • 4357 Answers
SOURCE: hole in pipe at bottom of dishwasheris this a water pipe or heat
Replace it., but I suppose you figured that....
Posted on Sep 18, 2009
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
My model DU810swkqo dishwasher will not drain completely [leaves about a couple of qts of water in the bottom after cycle.It has started dripping water out the bottom of the door.Can or does it need drain...
Hello
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 06, 2011 | Dishwashers
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Not cleaning well leaving film
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Ryle
Dec 05, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Not cleaning dishes clearly
Hi
Thanks
Rylee
Nov 11, 2009 | Dishwashers
Water isn't draining.
Thanks for contacting fixya.com
Nov 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Portable Dishwasher wont drain GE Model #GSC3508K00WW
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check the sump area for paper or any other large object clogging the drain. A cup or so of water in the sump area of your dishwasher is normal and it is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it’s possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
If the motor doesn’t turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
if you need to buy any parts, I have had alot of help from http://www.apwagner.com
Small objects can sometimes get stuck in the pump. When this occurs, you’ll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.There's a few things you can look into that won't cost you any money.
Oct 26, 2009 | GE 24-7/8" Convertible Portable Dishwasher...
Whirlpool dishwasher doesn't clean very well
Hi
Thanks
Rylee
Oct 22, 2009 | Whirlpool Dishwashers
Not working 100%
One the water in the bottom of the machine is more than likely becuase it is not draining properly reason?
Thenpump or drain pipe could be blocked or the filter or outlet at the bottom of the unit is clogged with food,Two are you useing dishwasher powder or blocks and not dishwashing liquide,three chech the wash arem holes are not clogged with food all holes must be open if two or so clogged it will spin the arm but will not wash properly and naturally will not rinse properly they must aslo be clean.Last make sure the machine is heating the water and not trying wash cold do this by stopping the machine mid cycle and open the door is there steam if so cool leave it to finnish the wash so clean filter ,wash arms,drain pipe blow into it and see if ant food particals appear in the machine,
Hope this helps
Jan 23, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher won't clean properly anymore.
sounds like the hose is clogged... i used to fix these.
first check to make sure the drain inside of the dishwasher (located on the bottom usually towards the back) does not have food clogging the drain. if there is nothing there than its more than likely a hose underneath the dishwasher. make sure you turn the water off before trying to fix this.
Sep 28, 2008 | Dishwashers
Whirlpool 24 in. DU910PFG Built-in Dishwasher Logo
56 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
