Question about Samsung Refrigerators
Rs27kgrs el refrigerador no funciona samsung - Samsung Refrigerators
SOURCE: mi nevera no esta enfriando en el lado del refrigerador
cambiale tambien el bimetalico y la resistencia tambien podria ser le desconectas los 2 cables de lado a lado de la resistencia que esta en el freezer y le pones un cable 110 y lo conectas si ve que se pone caliente la misma esta buena pero si no puede ser parte del problema , cuando estos problemas pasan hay que buscar en el timer,bimetal y resistencia
Posted on Mar 11, 2010
heatman101
  • 43501 Answers
SOURCE: MI REFRIGERADOR SE DESCONGELA UN DIA SI Y EL OTRO
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
guru_fixya
  • 944 Answers
SOURCE: El refrigerador dejo de enfriar.
This problem could arise due to various reasons.
1)Start relay is bad.
2)Over load to the compressor.
3)Dirty condenser,should clean it.
4)condenser fan motor not running.
5)compressor not running.
To check the compressor properly you should test it with an amp meter.if the compressor is drawing too much current, this may be why it is shutting off some relays will be easy to notice they are broken with them,they may be burnt.Replace it.Check if the windings in the compressor gives reading for each terminal.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
  • 51 Answers
SOURCE: NECESITO EL MANUAL DE USO
Go to the Webside and Google www.whirlpoolmanual
Posted on Oct 24, 2010
  • 1796 Answers
SOURCE: HOLA SOY SANDRA, TENGO PROBLEMAS
Hi!! Primero asegurate que el control de la temperatura del congelador este aproximadamente en el numero 3. Cuando dices que el congelador no se apaga, quieres decir que el ventilador del congelador esta prendido siempre, correcto? Si el ventilador esta prendido, el compressor y el ventilador que estan abajo, detras del refri tambien deben de estar prendidos chequea por favor. Si esto es correcto, desconnecta el refrigerador por unos 20 min. y luego lo connectas de nuevo, esto hara que el timer se haga reset, si ese es el caso, el problema se solucionara. Si no me envias un comentario y tratamos algo mas. Estuve buscando un manual para tu unidad pero no he encontrado ninguno en espanol, voy a seguir buscando.
Si le haces click en este link, te va a llevar a donde esta un diagrama de las partes the tu unidad, si tenemos que tratar algo mas, te va a ser util para saber cuales son las partes y sus nombres y me puedas entender mejor. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Parts%20List%20(SP)%20-%20WRT18AECLM00.pdf
Avisame lo que pase por favor.
Posted on Jan 11, 2011
Que significa el codigo de error EE? en el display .
posible termistor en cortocircuito en el evaporador refrigerador o el cableado del termistor. el corto es m?s que probable que en el conector del termistor. el trabajo debe ser realizado por un profesional capacitado.
Feb 28, 2015 | Sub-Zero 632 / S
EL COMPRESOR DE MI REFRIGERADOR NO ENCIENDE, NI HACE NINGUN SONIDO, QUE PUEDE ESTAR FUNCIONANDO MAL?
probablemente el relay se quemo y no esta pasando corriente compra un 3 in 1 starter pack ( relay, capacitor y overload) en cualquier lugar donde vendan o reparen refrigeradores y con eso se te soluciona el problema
Jul 14, 2014 | Frigidaire Refrigerators
Donde se encuentra ubicadoel el sensor que enciende y apaga el fan cuando el refrigerante se calienta Saturn 97
El sensor se encuentra en el pase del líquido refrigerador en la parte posterior de la culata.
Fig. 5: Removing the coolant temperature sensor
Hope helps (remember to rate this answer).
Jan 11, 2011 | 1998 Saturn SL
Whirlpool et18gk freezer working frige not
Since we know the machine is producing cold, that is a plus. The cold is created in the freezer. From here, a fan moves it through vents into the frig. From the frig it goes back into the freezer and makes a big loop.
What you probably have here is a motor to the fan in the freezer gone out. If you want to fix it yourself I'd be happy to tell you how. If you want to know if it's worth fixing, I would say most definitely. I would expect $40-$80 for the fan motor then labor on top of that. The fan part number is 2315539.You should be able to order the part anywhere that sells appliance parts by that number with no problem at all.
Jun 02, 2010 | Whirlpool ET8WTEXV (183 cu ft) Top Freezer...
Freezer door was slightly ajar overnight.now i can't get the freezer to cool even on power freeze.what should i do
What you will need to do is remove your food to another location. Unplug or turn the unit off for at least 24 hours. What has happened is the coils have become clogged with ice. Once you let it melt out it should work fine. You may end up with some water on the floor. Leave the doors opened and lights should be unscrewed so they do not stay on. And take care.
Thanks for asking.
May 22, 2010 | Samsung RM255LASH Side by Side...
Mi nevera no esta enfriando en el lado del refrigerador
Feb 23, 2010 | Frigidaire FRS26R4A Side by Side...
My refrigerator wont stay cold and it got this annoying clicking sound
El congelador funciona po se cubre de hielo pero el refrigerador no enfria cual es la solucion
Aug 12, 2009 | Refrigerators
No funciona
Este refrigerador tiene muchos problemas con la tarjeta de control (control Board)cambiela y funcionara de nuevo. la tarjeta de control esta en una caja blanca al lado de la valvula de agua This fridge has lots o problems whit the control board just replaced and shut work again Note The control boar is inside a white box next to the water valve
Dec 08, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
63 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
