Question about Breville BTA820XL 2-Slice Toaster
Toast won't come up - Breville BTA820XL 2-Slice Toaster
Won t go into park have to start it in nutral
the PNRDL switch is bad.
the P contacts are toast.
and are always 10x the first to go.
due to used 10x more.
or more.
it just a contact.
slim chance , linkage misadjusted. its in the FSM this procedure.
Feb 11, 2014 | 1999 Toyota Sienna
AL-A1 turntable won t turn
take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
Jan 19, 2014 | JVC Audio Players & Recorders
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
What if my tv won't go on?
Likely had units on and more than one connected to same speakers--fed back into set and now damaged power supply in the TV--seen this before--looked in one set and both audio output devices toasted---problem happens so fast it gets back to set's power supply and takes out parts there also--shop repair.
Oct 22, 2012 | Panasonic Televison & Video
Camera won't turn on
Yes! the cost to repair would not be practical, this is a systems control board issue.
Mar 12, 2012 | Samsung Digimax A503 Digital Camera
Breville BTA820XL 2-Slice Toaster Logo
43 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
