Thermostat 2v781897 - Heating & Cooling
Changing thermostat v6
drain coolant until its below the thermostat.then remove two thermostat housing bolts.remove thermostat housing and thermostat.make note position of thermostat before removing it.then carefully clean all old gasket material from thermostat housing and cylinder block you can buy can gasket remover at any auto parts stores.buy new thermostat gasket.if you have the paper type you need to buy RTV SILICONE to help seal gasket if you have rubber type gasket you dont need RTV SILICONE.make sure both surfaces are clean.then install new thermostat and new gasket.if you have paper type gasket apply thin 1/16 coat RTV SILICONE both sides thermostat gasket.then install gasket to thermostat housing then install housing to cylinder block first make sure new thermostat in place before installing thermostat housing. let RTV silicone sit up about hour before adding coolant.IF THERMOSTAT HAS THE O RING SEAL DONT NEED RTV SILICONE AND THE PAPER GASKET.
Jul 01, 2013 | Mercury Sable Cars & Trucks
Tip
Programmable Honeywell
A Programmable Honeywell Thermostat is a great investment for you to make for your heating and cooling system. A Honeywell Thermostat will provide you with the best in comfort and dependability for many years.
Many people when they think of Honeywell Thermostats think of the old round T87 thermostat that has been one of the most common thermostats for years and years.
Today they have those thermostats in designer colors and they are still made and used in many situations. But the manual thermostat is quickly becoming a thing of the past. With the rising costs of fuel the Programmable Honeywell Thermostat is becoming more and more popular. Programmable Thermostat Honeywell is even one of the most popular searches when it comes to thermostats.
The VisionPro thermostat line has quickly become one of the leading digital programmable thermostats on the market to today. The ease of programming this thermostat and the touch screen interface has made it a very popular choice for many people. There is a variation of this thermostat for virtually any possibility that you can think of. The FocusPro line also is a very good choice at a bit less cost. There is a basic Pro line and also even a digital thermostat in the traditional round configuration. Both digital programmable and basic digital thermostats are available for line voltage control of electric heating.
Along with the thermostats you now are able to add remote outdoor sensors as well as install you thermostat in a remote place and run a sensor to the space you are controlling. For many years these capabilities were standard for commercial thermostats, but now they are a very real possibility for home use also. With an outdoor sensor these thermostats now have the capability to turn off your heat pump and start you backup heat a certain preset out door temperature. In the past many systems have been installed with complicated electronic to do what a thermostat can do very easily.
The Programmable Honeywell Thermostat has come a long ways in the past few years. The changes have made this thermostat capable of doing many unbelievable things. If you are looking to replace your old thermostat, carefully compare the many thermostats on the market and then pick the one that will meet your needs the best. For many the Honeywell digital thermostat will be the best choice, giving them great flexibility and reliability in one thermostat.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
on Jan 15, 2010 | Heating & Cooling
Need to know how to replace the thermostat on a 1996 buick century wagon 3.1 6 cylinder engine
Trace the upper radiator hose to the mounting area on the intake manifold. Loosen the hose clamp on the manifold end of the hose and remove the hose. Pull the thermostat out of the intake manifold.
For more help and troubleshooting go through the help links below:---
Click the link below:-----
THERMOSTAT REMOVAL PROCEDURE/LOCATION DETAILS
Where is Thermostat Located on Saturn
http://technoanswers.blogspot.com/2012/11/where-is-thermostat-located-on-saturn.html
2004 Dodge Intrepid: How to replace Thermostat?
http://schematicsdiagram.blogspot.in/2012/06/2004-dodge-intrepid-how-to-replace.html
How to Replace Thermostat on Audi A4?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-audi-a4.html
How to replace Thermostat on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-acura-car.html
Where is thermostat located on 2006 dodge magnum 3.5L?//
http://repairhelpcenter.blogspot.com/2011/10/where-is-thermostat-located-on-2006.html
Thermostat on AUDI 1.9 TDI?
http://repairhelpcenter.blogspot.com/2011/10/thermostat-on-audi-19-tdi.html
How to replace Radiator on Audi and VW car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
How to Replace a Thermostat.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-thermostat.html
How to locate Thermostat on Any car model?
http://schematicsdiagram.blogspot.com/2011/12/how-to-locate-thermostat-on-any-car.html
Where is thermostat on Audi A6?
http://technoanswers.blogspot.com/2011/12/where-is-thermostat-on-audi-a6.html
How to replace thermostat on 1992 Buick century?
http://technoanswers.blogspot.com/2011/12/how-to-replace-thermostat-on-1992-buick.html
Replacing thermostat on 1999 Mercury Cougar?
http://technoanswers.blogspot.com/2011/12/replacing-thermostat-on-1999-mercury.html
Thermostat Replacement on Toyota Corolla?
http://technoanswers.blogspot.com/2011/12/thermostat-replacement-on-toyota.html
Where is thermostat located on 2005 Dodge neon?
http://schematicsdiagram.blogspot.in/2012/02/where-is-thermostat-located-on-2005.html
These will help.
Thanks.
Nov 28, 2012 | Buick Century Cars & Trucks
Where is thermostat on my 2005 chevy classic
Thermostat Removal & Installation 2.2L Engine 2004-2005 To Remove:
  2. Remove the thermostat housing-to-water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
  3. Remove the water pump feed pipe from the thermostat housing .
  4. Remove the thermostat from the housing.
To Install:
  1. Install the thermostat on the housing.
  2. Install the water pump feed pipe on the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Fill the cooling system.
2006-2007 To Remove:
  1. Drain the cooling system.
  2. Disconnect the radiator outlet hose from the surge tank and thermostat housing cover. Thermostat & cover gm-03-39-3601.gif
  3. Remove the mounting bolts and remove the thermostat housing cover.
  4. Remove the thermostat from the housing. Discard the O-ring.
To Install:
  1. Using a new O-ring, install the thermostat on the housing.
  2. Install the thermostat housing cover with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Connect the radiator outlet hose to the surge tank and thermostat housing cover.
  4. Fill the cooling system.
3.5L Engine (LZ4) W/ Variable Valve Timing & 3.9L Engine To Remove:
  2. Remove the air cleaner outlet duct.
  3. Disconnect the radiator outlet hose from the thermostat housing. Thermostat 3.9L gm-03-00-3054.gif
  4. Remove the mounting bolt/stud and remove the thermostat housing.
  5. Remove the thermostat from the engine.
  6. Clean the sealing surfaces.
To Install:
  1. Using a new gasket, install the thermostat on the engine.
  2. Install the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Connect the radiator outlet hose to the thermostat housing.
  4. Install the air cleaner outlet duct.
  5. Fill the cooling system.
  6. Check the cooling system for leaks.
3.5L Engine (LX9) W/O Variable Valve Timing To Remove:
  1. Drain the coolant.
  2. Disconnect the radiator hose from the thermostat housing. Thermostat 3.5L gm_mv_ven_tstat.gif
  3. Remove the mounting bolt/stud and remove the thermostat housing.
  4. Remove the housing gasket.
  5. Remove the thermostat.
  6. Clean the mating surfaces.
To Install:
  1. Install the thermostat on the engine.
  2. Install the thermostat housing and gasket with the mounting bolts. Tighten 18 ft-lb (25 Nm).
  3. Connect the radiator hose to the thermostat housing.
  5. Check the cooling system for leaks.
Jan 29, 2011 | 2005 Chevrolet Malibu
Have a kenmore model # 110.72822101, where's the thermostat located, my dryer gets hot then cold
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Nov 08, 2010 | Kenmore 72822Gas Dryer
Thermostat replacement 1994 nisan sentra 1.6 eng how to remove and replave
JUST DRAIN COOLANT LEVEL BELOW THE THERMOSTAT. CATCH COOLANT IN A DRAIN PAN UNDER RADIATOR.THEN REMOVE RADIATOR HOSE FROM THERMOSTAT HOUSING ON THE CYLINDER BLOCK.THEN REMOVE THERMOSTAT HOUSING AND THERMOSTAT.CLEAN THERMOSTAT HOUSING SURFACE AND THERMOSTAT HOUSING SEALING SURFACE ON CYLINDER HEAD.INSTALL NEW THERMOSTAT IN PLACE,MAKE SURE THERMOSTAT AIR BLEED HOLE FACING LEFT SIDE UPWARD ON THE ENGINE.SOME THERMOSTAT HAS TOP STAMPED ON IT.MEANING MUST BE FACING UP.WHEN THERMOSTAT IN PLACE.TAKE NEW THERMOSTAT GASKET.PUT SEALER ON BOTH SIDES OF GASKET.THEN.PUT GASKET ON THERMOSTAT HOUSING.THEN PUT HOUSING IN PLACE TORQUE HOUSING BOLTS 16 - 20 FT LBS.WAIT 1 HOUR UNTIL GASKET SEALER CURE.THEN FILL UP COOLANT SYSTEM.BLEED COOLANT SYSTEM AND CHECK FOR LEAKS.
Sep 17, 2010 | 1994 Nissan Sentra 4-Door
Replacing the thermostate
drain out coolant in a drain until below thermostat level follow radiator hose to engine cylinder block to thermostat housing.remove thermostat housing than remove thermostat.replace with a new o-ring on thermostat before installing new thermostat.make sure thermostat housing surface and engine block surface clean.before installing new thermostat.
Aug 16, 2010 | 1997 Isuzu Trooper
Need to find where the thermastat is on a 2003 cadi
It is in the rear of the engine by the firewall and the intake manifold will need to be removed to gain access t it.
Engine Coolant Thermostat Replacement (LA3, LY9) Removal Procedure
  1. Remove the thermostat housing. Refer to Engine Coolant Thermostat Housing Replacement .
  3. Complete the following in order to remove the thermostat from the thermostat housing:
  4. 2.1. Depress the ears on both sides of the thermostat. 2.2. Rotate the thermostat until it clears the retaining feature of the housing. 2.3. Release the pressure from the thermostat. 2.4. Pull the thermostat from the thermostat housing.
Installation Procedure
  1. Complete the following in order to Install the thermostat into the thermostat housing:
  2. 1.1. Align the thermostat pin to the thermostat housing orifice. 1.2. Depress the ears on both sides of the thermostat. 1.3. Rotate the thermostat until it aligns with the retaining feature of the housing. 1.4. Release the pressure from the thermostat.
  3. Install the thermostat housing. Refer to Engine Coolant Thermostat Housing Replacement .
Jul 10, 2010 | 2003 Cadillac CTS
Where is the thermostat
Please choose the correct steps for the size of engine that you have:
4.5L & 4.9L Engines
  1. Drain the coolant to a level below the thermostat housing.
  2. It may be necessary to remove the upper air filter assembly on some models.
  3. Remove the 2 bolts securing the upper thermostat housing to the lower housing.
  4. Remove the upper thermostat housing.
  5. Remove the thermostat and O-ring from the lower housing.
Thermostat installation—4.5L and 4.9L engines
To install:
  1. Install the thermostat and a new O-ring to the lower housing.
  2. Install the upper thermostat housing to the lower housing. Tighten the thermostat housing bolts to 20 ft. lbs. (27 Nm).
  3. Refill the cooling system using a 50/50 mixture of water and ethylene glycol antifreeze.
  4. Start the engine and check for coolant leaks. Allow the engine to come to normal operating temperature. Recheck for coolant leaks.
4.6L Engines
  2. On some vehicles, access is easier if the front-end beauty panel and the air cleaner are removed.
  3. Remove the 2 bolts securing the thermostat housing to the intake manifold.
  4. Remove the thermostat housing.
  5. Remove the thermostat and O-ring from the housing.
Thermostat installation—4.6L Engine
Loosen the upper radiator hose clamp at the thermostat housing
Remove the upper radiator hose clamp from the thermostat housing
Remove the thermostat housing retaining bolts and . . .
. . . remove the thermostat housing from the engine
Separate the thermostat from the housing
To install:
  1. Install the thermostat and new O-ring to the housing.
  2. Install the thermostat housing to the intake manifold. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  4. Install the air cleaner and beauty panel, if removed.
  5. Start the engine and check for coolant leaks. Allow the engine to come to normal operating temperature. Recheck for coolant leaks.
May 23, 2010 | 1996 Cadillac DeVille
How do I remove the thermostat from my 2001 chevy venture
2001 Chevrolet Truck Venture FWD 3.4L SFI 6cyl
  1. Remove the air cleaner and duct assembly.
  2. Drain the coolant until the coolant level is below the thermostat.
  3. Remove the crossover exhaust pipe.
  4. Remove the radiator hose from the thermostat housing.
  5. Remove the thermostat housing bolts and clean any sealer from the bolt threads.
    Fig. Remove the housing bolts
  6. Remove the thermostat housing and gasket.
  7. Remove the thermostat.
  8. Clean the mating surfaces.
To install:
Fig. The removal and installation of the thermostat
  1. Install the thermostat.
  2. Install the thermostat housing and gasket.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  3. Install the thermostat housing bolts and tighten them to 18 ft. lbs. (25 Nm).
  4. Install the radiator hose to the thermostat housing.
  5. Install the crossover exhaust pipe.
  6. Install the air cleaner and duct assembly.
  7. Fill the cooling system.
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove the air cleaner intake duct.
  3. Partially drain the cooling system.
  4. Remove the radiator inlet hose from the thermostat housing.
  5. Remove the thermostat housing bolts.
  6. Remove the thermostat.
  7. Clean and inspect the thermostat housing gasket mating surfaces.
To install:
  2. Install the thermostat housing.
  3. Install the thermostat housing bolts and tighten to 18 ft. lbs. (25 Nm).
  4. Install the radiator inlet hose to the thermostat housing.
  5. Install the air cleaner intake duct.
  6. Fill the cooling system.
  7. Start the engine and check for leaks.
3.9L Engine
  2. Drain the cooling system.
  3. Release the tension on the hose clamp at the thermostat housing and remove coolant hose.
  4. Remove the thermostat housing mounting bolts and remove the thermostat housing.
    Fig. Remove the thermostat housing to access the thermostat-3.9L engine shown
To install:
  2. Install the thermostat housing and tighten the bolts to 18 ft. lbs. (25 Nm).
  3. Install the coolant hose to the thermostat housing and install the hose clamp.
  4. Refill the cooling system to the correct level.
  5. Start the engine and check for leaks.
I hope help you whit thie (remember rated this help) Have a nice day and good luck.
Sep 23, 2009 | 2001 Chevrolet Venture
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
