Question about Sanyo PLV-Z4 Multimedia Projectors
Reset remote for sanyo projector sanyo Xtra PLC-xe40
How to reset the remote
Fusiondc
  • 47 Answers
SOURCE: USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Posted on Jan 17, 2008
Marrie
  • 563 Answers
SOURCE: Sanyo PLC-XU86/83 Usb cable Problem
Hi there
It might be that you are using the port for this function.
I suspect that you are using the one on the side of the unit - instead of the smaller usb port at the back - which is actually the one that should be used for this function.
The USB port on the side is made for a flashdrive.
Posted on Apr 10, 2008
  • 3 Answers
SOURCE: overheat reset switch for Sanyo PLC-Z4 projector
check the other questions on this topic, I just posted a detailed answer, and that was based on another's answer.
Posted on Aug 01, 2008
  • 84 Answers
SOURCE: Sanyo PRO xtraX Multimedia Projector Mod.# PLC-XP1ONA
this is the normal condition> only when green led is off and warning temp led(yellow) is on something is wrong!!
Posted on Sep 25, 2008
Master Rod
  • 7 Answers
SOURCE: Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Posted on May 08, 2009
Picture dull colours incorrect on sanyo pro xtra x projector
reset to factory default settings (from the menu). after that if it's not where you want them, you can go into the menu and set them to where you like them.
Aug 04, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Projection issue
sounds like you might need to change the KEYSTONE settings
Nov 14, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XE31
Sorry if this is a bit late...
Hold down the MENU and IMAGE buttons on the remote for more than 10 seconds and the remote toggles to the other projector.
Banni
Nov 04, 2008 | Sanyo FOR PLC-XE31
Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Jul 01, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo PLV-Z4 Multimedia Projectors Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
