Question about Caterpillar Cat 345b L Engine & Pump Control System Manual
345b overheating works about a hr overheats fan working
Hi i have isuzu npr 2010 and have overheat problem if motor work slow not have problem but during the presser working have overheat problem if stop and motor work slow become normal
If I'm understanding u right, u overheat when the AC is not on?! If so, it sounds like the electrical fan for the AC is working & the electric, radiator cooling fan is not operating. This may be caused by a bad fan switch, coolant sensor fan relay, electrical short to the fan or it may be a simple fuse. Good Luck
Mar 16, 2017 | Isuzu Cars & Trucks
Cooling fans work then dont
Possibly faulty cooling fan relay... the fan has an override when the A/C comes on. (Wouldn't be a faulty temperature sensor, or the fan would work when overheating.)
Jun 24, 2015 | 2010 Ford Transit Connect
Overheating and F1
Check your fuses. your fan fuse might be blown.
Jan 10, 2014 | 2005 Suzuki Burgman 650
NORTHSTAR ENGINE OVERHEATS
could be a couple of things1 you have a leak 2 the radiator is blocked run some radiator flush for about 1/2 hr drain then refill with water 3. is the fan working 4 you could have blown the head gasket open the radiator cap see if the water bubbles out 5 the thermastat could be shot.
Feb 27, 2013 | 1998 Cadillac DeVille
Car overheat when first run turn car off and back on and car run cool
You might need to replace fan assembly and/or thermostat. Mine was overheating only when stopped at traffic lights. Only one fan was working and would cause the car to overheat. Working great after fan swap.
Jun 20, 2012 | 2002 Dodge Intrepid
Overheating of graphics card while playing games
  • Clogged fan
The main device responsible for maintaining a constant temperature of your video card is the fan present in the processor. If this isn't functioning efficiently it's quite obvious that it would result in your video card overheating. If you don't regularly clean your computer, it could be highly likely that your fan is clogged with dust.
This is one of the simplest causes of your video card overheating which can be fixed by simply cleaning your fan, preferably using a blower.
  • Broken fan
A follow up of the previous point, in some cases your fan maybe malfunctioning or stopped working altogether. This could simply be diagnosed by switching on your computer with its cover open and checking if the fan is functioning. If it doesn't happen to be working, you have your answer.
  • Overclocking
Pushing your CPU to its limits by overclocking can cause your video card to overheat. This can seem fairly obvious too as if you find your video card overheating and if you've recently overclocked your CPU, it would explain it.
  • Faulty Drivers
This is a rare cause, but depending on your video card's brand a badly developed driver could also cause your video card to overheat. If you use an unusual video card with questionable reputation this could be the issue.
  • Inefficient Airflow
While your fan maybe perfectly in tact and working, the location of your fan also matters. If there isn't sufficient air flow to your video card it can also cause it to overheat.
Those are typically the 5 main reasons to your video card overheating. If you have any other points in your mind, feel free to share them below.
May 09, 2012 | ASUS GeForce GT240 1G DDR3 550Mhz
Overheating my car continuously overheat
CHECK FOR LOW COOLANT LEVEL AND REPLACE THERMOSTAT AND THE RADIATOR PRESSURE CAP.IF CAR OVERHEATING AND COOLING FAN NOT WORKING.CHECK COOLANT FAN FUSE AND RELAY.IF BOTH OKAY,HOT WIRE COOLANT FAN,IF FAN WORKS, PROBLEM COULD BE FAULTY COOLANT TEMPERATURE SENSOR,OR FAULTY PCM, IF COOLING FAN DONT WORK WHEN YOU HOT WIRE FAN.THE COOLING FAN ASSEMBLY NEED REPLACING.
Apr 22, 2011 | 1993 Lexus Es 300
Honda 2001 civic replaced radiator, electric fan not working and overheats..why/
HOT WIRE FAN IF ITS DONT WORK COOLANT FAN FAULTY.IF COOLANT FAN RUNS WHEN HOT WIRED. COOLANT TEMPERATURE SENSOR FAULTY OR LOOK FOR BLOWED FUSE AND FAULTY COOLANT FAN RELAY.WHEN YOUR FAN WORKING AND VECHICLE STILL OVERHEAT REPLACE THERMOSTAT.
Jan 01, 2011 | 2001 Honda Civic
My 2005 element engine overheats at idle
Check fan for operation.
Please see my tip at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines and let me know if you have questions.
Sep 21, 2010 | Honda Element Cars & Trucks
Fans dont work and overheats 94 toyota tercel
Most systems work pretty much the same. First check the fans themselves by hot wiring them to the battery. If they work, you need to check the engine temp sensor (some vehicles use one for gauge and fans, others use a separate one for fans) relay, and of course any fuses.
You will help yourself a lot by getting either a chilton or haynes manual to show you how to do testing.
Jun 20, 2010 | 1994 Toyota Tercel
Caterpillar Cat 345b L Engine & Pump Control System Manual Logo
74 people viewed this question
Top Caterpillar Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Caterpillar Plumbing Expert? Answer questions, earn points and help others
