Question about Microsoft Windows Vista Ultimate Edition
Permission denied error when access hidden folders
I have recently installed Fixya and I can't access some of the hidden folders, for example the hidden "SendTo" link in my documents. For some reason it give me "permission denied error" Does anyone have any idea why? Luiz
  • JANOPOLJOVKA Aug 20, 2008
    DRIVER FOR ASUS ADSL MODEM
Hhh[
Posted on Oct 24, 2008
When i log on msn my friends are told me that i send some file whic they siad about the pic but i dont understand that and i dont send any fil to them some 1 said it's virus could som1 help me please
Posted on Dec 21, 2007
    Problem Solver:
  • 21 Answers
Good information Above,
Also would like to make a statement.
I recognized this in Vista anything you do you have to logged on as Admin.
all you have to do if u want to see hidden files, Right Click and go into the Properties, on top their should be a tab called Security click it.
then Under Group or User Names:
choose Administrators, highlight/select it then click ok.
now you should be able to see the Hidden Files.
Hope this information helps.
TY
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
1. Click Start
2. Click Control Panel
3. Select System and Maintenance
4. Click Administrative Tools
5. Double-click System Configuration
6. Click Continue (if prompted)
7. Select the Tools tab in the System Configuration window
8. Here you can choose Disable UAP or Enable UAP from the bottom of the
listbox
9. Click Launch
10. Reboot
Good luck. Hope my solution was helpful.
Posted on Oct 24, 2007
ابي الثيم بأي طريقه ما عرفت لي اسبوع ادوره ما جبته
Posted on Sep 20, 2008
SOURCE:
I have been denied permission to access this folder
Right click the folder and choose properties. Now under the security tab select advanced settings. Then now select the owner tab and assign ownership to administrator account.26 Apr 2013
how to fix "you have been denied permission to access this folder ...
denied permission to access this folder Google Search
Dec 23, 2016 | Computers & Internet
Tip
Windows Vista. Access is Denied error message when you try to open a folder or a...
Some of us may have encountered this error especially when opening folder like system volume information for example. You can take ownership of that folder, This is also helpful when you have just cleaned up your system of virus but you cannot open certain drives or folders.
You can also use this technique to disable the permissions of other administrators of the system so that no one but YOU can access the folder.
First I am gonna show you how to take ownership of folders. If you are looking for changing permissions to a disk drive, the please click here4809962.gif
if you are logged in as the administrator by following the steps below.
1)Right click on the folder and click properties.
2)Remove the read only check box and click apply.
3)Click on the security tab and click advanced.
4)Click on the owner tab.
5)Click on the Edit button since you want to edit the permissions.
6)This window should pop up. Select your username if you want exclusive access or select administrators to allow all administrators to be able to access it and check the box replace owners on subcontainers and objects.
7) A window will pop up asking you to confirm. Click YES.
8) A message will pop up asking you to close the folder and re-open. Click ok.
9)Close folder and re-open it and you will now be able to open it
Thank you for reading :)
Sai.
on Feb 19, 2010 | Computers & Internet
Wd my passport retrieve data
Step 1:
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ...... Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Feb 08, 2013 | Western Digital 1TB My Passport Essential...
Iomega 1tb drive have files hidden
Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available. Hope this helps.
b>
Dec 10, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
Error Creating Folder 1008:9,-5000 Access Denied Error
You should already have read/write access to your own Application Support folder. If you are referring to the /Library/Application Support folder, repairing permissions should set the proper permissions on the folder, but probably not the contents (you really shouldn't change permissions on system files and folders). Trying to move or change permissions on the contents of an entire folder may also fail if there are items in there that you don't have access for, such as those owned by another user (check the permissions of the specific folder that you are trying to copy to).
Oct 08, 2012 | Computers & Internet
How can i fix error 1404 on microsoft office 1010
  1. If you receive the "Error 1404" error message, remove the registry subkey that is referred to in the error message. To do this, follow these steps:
    Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
    1. Click Start, click Run, type regedt32 in the Open box, and then click OK.
    2. Locate the registry subkey that is referred to in the "Error 1404" error message. Make sure that you locate the exact registry subkey that is specified in the error message.
    3. Right-click the registry subkey that you located in the previous step, and then click Permissions.
    4. Under Group or user names, click Administrators, click to select the Full Control check box under Allow, and then click OK.
    5. Right-click the registry subkey, and then click Delete.
      When you are prompted to confirm the deletion, click Yes.
  2. Start Windows Explorer, and then locate the drive:\Winnt\Installer folder. In this folder location, drive is the hard disk where Windows is installed.
    Note This folder may be hidden. If the drive:\Winnt\Installer folder does not appear in Windows Explorer, follow these steps:
    1. On the Tools menu, click Folder Options, and then click the View tab.
    2. Under Advanced settings, click to select the Show hidden files and folderscheck box, and then click OK.
  3. Grant appropriate access permissions for the drive:\Winnt\Installer folder for the following groups: Administrators: Full Control
    SYSTEM: Full ControlTo do this, follow these steps:
    1. Right-click the drive:\Winnt\Installer folder, and then click Properties.
    2. Click the Security tab.
    3. In the Name list, click the appropriate user group or user name that you want to assign permissions for. For example, click Administrators.
    4. Under Allow, click to select the check box for the appropriate permission that you want to set, and then click OK. For example, click to select the Full Controlcheck box, and then click OK.
  4. Restart the computer.
  5. Insert the microsoft office CD into the CD or DVD drive, and then run the microsoft office Setup program.
  6. After the microsoft office Setup program has completed running, reinstall your antivirus software program.
Nov 10, 2010 | Microsoft Office 2003 Basic Edition...
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
http://www.rarlab.com/rar/wrar391.exe
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
Dec 30, 2009 | Compaq Computers & Internet
Error 101 (net::ERR_CONNECTION_RESET): Unknown error. I use Google Chrome and I get the above message - whenever I try to log onto Facebook on my laptop I have cleared all offline content and swept up...
sometime get me error 101, when I try to open only Gmail site in IE, Google crome & when I try to after 15 mints its opening. Give me below error:
plz help me
Sep 10, 2009 | Google Chrome
Help with HP Deskjet D1560 Printer!!
Solution 1
Right click on setup file and select run as administrator
Solution 2
  • open registry editor, start -> run -> type in: regedit
  • Open Hkey_local_machine folder
  • Open System folder
  • Open Currentcontrolset
  • Right click with mouse on enum
  • Select Permissions
  • make sure user: SYSTEM has FULL CONTROL permission
  • See picture:
Make sure system has Check On Allow Full control and read.
Check all users listed that there are no checks on deny.
You can also press ADD to add your own user, then click advanced, then click find now , select your user, click ok, click ok, give your
user full control and read permission.
Apply and ok. double check that there are no Deny permissions set.
let me know the results and do not rate solution untill we have solved the problem.
Thanks,
Ekse
May 05, 2009 | HP D1560 Deskjet Printer InkJet
Mac Error
Hi Joe
Sound like a permissions problem.
Make sure you have admin rights on your log in or log in as admin. Check the permissions on the application folder, that you have read and write (single click on the folder press option and 'i' key to get folder info.
With Macromedia it installs folders in quite a few locations so you need to make sure you have 'read/write' permission on the whole mac.
If you still have a problem. Open the apple disk utility (in the utility folder in applications) and check permissions there. You can run fix permissions from the to.
Paul
Sep 07, 2008 | Apple Mac OS X 10.4
Microsoft Windows Vista Ultimate Edition Logo
853 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
