Question about Honeywell Windmere Electric Heater
Knob for wattage control for Windmere 3180 comfort furnace
I need a new know that controls off-fan-1000w-1500w on my Windmere 3180 comfort furnace
4 Suggested Answers
SOURCE: Oil furnace fan on all the time
who cares
Posted on Feb 06, 2009
billyvangogh
  • 108 Answers
SOURCE: honeywell s861ou 3009 intermittent pilot module
What is the wire on the old control.....what terminal is it on??....When replacing old controls the new ones often have different terminals and sometimes incorporate some terminal internally etc....the Wiring Diagram included should be followed exact....if it's working fineit's likely ok....if you have any doubt have it looked at by an expert
Posted on Oct 26, 2009
aquaman987
  • 927 Answers
SOURCE: blower fan running constant after new fan and
Here's my best shot.
Check the temperature settings for the fan switch.
The low OFF setting should be about 100 degrees.
The ON setting should be around 150 degrees and this is the setting that "makes" the ON contacts.
The HIGH LIMIT setting should be about 180 degrees.
If these are set, can you use a meter to see if the FAN ON contacts are closed?
Lastly, it appears that one hot line should go to one side of the blower and the other hot line should go to the bottom FAN terminal with the other side of the blower being fed by wiring from the top FAN terminal.
Good Luck. Gary
Posted on Feb 22, 2011
Goldstar Ma1011w
1000w-1500w
Hope I Helped
AS
Aug 17, 2014 | Microwave Ovens
I have 2 air conditioners on my Hampton trailer. I can't get my furnance to kick on. I have a R V Comfort .ZC duel control thermostat with zone 1 ,liveing room, and -Zone 2 ,bedroom, zone 2 will say gas...
I need to know what the furnace is doing .
Since you said furnace that's means force hot air and you have 2 Zone damper that's runs on 1 furnace ,correct?
If it's 1 furnace with 2 Zone is Zone 1 working
May 31, 2017 | Coleman Rv Air Conditioner Control Box...
Furnace intermittent on Comfort Control
It depends on what mode the unit is in when your looking at the screen. No call, no display. No errors, no display
Apr 11, 2014 | Dometic Heating & Cooling
Furnace refuses to cycle off even when room is 20 degrees warmer than setting
Do you know how to access your furnace wiring ? What make/model furnace?
Jan 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
My heil furnance comes on but no hot air or air at all
see this causes and fix it. God bless you
o light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps: Light the pilot:
  1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
  2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
  3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
Adjust the pilot:
  1. Remove any cap covering the pilot adjusting screw on a combination control.
  2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
Test and replace a thermocouple:
  1. Hold the control knob to pilot and light the pilot as above.
  2. Unscrew the thermocouple fitting with an open-ended wrench.
  3. Set a multimeter to the DVC (lowest voltage) scale.
  4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
  5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
  6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
  7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
  8. Remove the thermocouple from its mounting bracket.
  9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
  10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
  11. Turn on power to the furnace and relight the pilot (above).
Adjust an adjustable burner air shutter:
  1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
  2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
Clean removable burner tubes and ports:
  1. Shut off gas and power to the furnace.
  2. Unscrew or loosen and remove the tubes from the supporting bracket.
  3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
  4. Use a stiff wire to clear any debris from clogged ports.
Oct 08, 2012 | Honeywell Icp Heil Tempstar Furnace Spark...
Had a problem with the thermostat connected to GW-50-4 Wall furnace. One fan is not working at all, the other fan runs continuously even when the furnace isn't running. Is there a control swith or...
Jake, it sounds like the motor coil wiring on the blower that doesn't work may be damaged or has been disconnected.
Regarding the one that is still running. The automatic fan control is located on the bottom of the blower assembly. The fan control is a nonadjustable, automatic type. The fan control will require between 3 and 7 minutes of main burner operation before the fan control "closes" and activates the blower. The blower will continue to run between 3 and 7 minutes after the main burner shuts off, before the fan control "opens" and deactivates the blower. In which case, if it continues to run and run and run, the fan control switch (part # R-2503) may have failed and will need to be replaced. You can order the part from Empire Comfort Systems Tech Service 800-851-3153. Have the Model Number, Serial Number of the heater handy, as well a the Part Number. when you call.
To help you further, I have included a link to the Owner's Manual for that model wall heater. You can download and print it for future reference.
http://www.empirezoneheat.com/assets//EHS/manuals/GWT-%2825,35%29_Manual.pdf
I hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Empire GWT-50 Wall Mounted Panel Heater
Empire FAW-60-2-spp fan short cycles about 4 seconds on/off
From what you have described, it sounds as if the Fan Control Switch, ECS Part # R-1941, which works in conjunction with the Limit Control Switch (ECS Part # 912073) is failing and needs to be replaced. You can order these parts directly from Empire Comfort Systems. If you decide to replace these parts yourself, it will give you an opportunity to thoroughly clean the interior of the Wall Furnace, if you haven't already. If you need further information, contact Empire Comfort Systems, Technical Service @ 800-851-3153 Monday - Friday.
Hope this helped you to troubleshoot the problem. Please don't forget to rate my response. Thanks!
Mar 27, 2011 | Empire Heating & Cooling
I have a Jantitrol GMP 100-3. When it works, an exhaust fan kicks in for a minute, then the flames go on and it starts to heat. Then what started to happen was the exhaust fan would go on for a bit, go...
"There is a significant dust source next to the furnace." You were headed in the right direction without knowing. Dust can certainly play a big role in creating the problem. When the furnace is operating it's sucking in the surrounding dust and lint. This can clog the electrical contacts, cause false readings to the control panel and other damage. If you feel comfortable doing it, you can clean it yourself. Just remember to turn OFF all power to the furnace, before removing the panels and working inside the furnace. A Shop Vac with a hose, brush attachment and crevice tool will be a big help in cleaning. If you don't feel comfortable making it a DIY project, call a qualified technician to perform the work.
Hope this helped you.
Mar 15, 2011 | Heating & Cooling
My comfort zone 1500wo isn't cycling on and off. Do you know what is happening & how to fix it?
Hi, I just got my comfort zone 1500w and same thing. I called Comfort Zone this morning at 1-800-221-6895, they are most pleasant and helpful. She said it was because I had it on the energy saving mode. When it is set to that the fan runs continuously and never shuts off. She said to put it to the low or high setting and once the temp is reached, it will automatically shut off. Then when the temp drops it will turn on. Cycling off and on doesn't work with the energy saving function - she couldn't really give me an explanation for it just said don't use it if I want it to cycle off and on. Hope this helps.
Dec 22, 2010 | Comfort Zone NEW 09 Electric Portable...
Honeywell Windmere Electric Heater Logo
119 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
