Question about Canon Office Equipment & Supplies
My canon lbp7660 gives the message e004-0000
I can turn the printer on and off again. This doesn't help. I also tried taking out the ink and put it back. That didn't help either.
  • 10 Answers
SOURCE: Service error 5C00
Service error 5C00 might indicate the purge system.
The "rattling sound " is probably coming from the (gears of-) socalled purge unit. May be one ( or both) of the ink tanks is not properly put back in again,or the printhead-lock is not locked. and the purge system is blocked.
Remove the ink tanks and remove the printhead, closw the printhead-lock, close the printhead cover, switch the printer of, switch the printer on again. If the rattling sound is still there, than you might have an expensive problem to be solved.
If the rattling sound is gone, there is probably something wrong with the printheadlock.
Posted on Mar 13, 2008
  • 153 Answers
SOURCE: Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
Posted on Apr 01, 2009
  • 153 Answers
SOURCE: MESSAGE 'CHECK INK U051 BLK COL'
just hold down the stop reset button for 10 seconds it will bypass the ink counter
Posted on Jun 08, 2009
  • 232 Answers
SOURCE: ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Posted on Apr 11, 2010
  • 4 Answers
SOURCE: MP560 Canon Printer Error 6C10
The above suggestion worked short term, but in about a couple of hours, I'd get the same old error code again. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
Don't know if you've found an answer to this problem yet, but I had the same issue for about three months. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
For months, I've had to power off, disconnect from computer, and power on again to kick-start the printing. It was driving me crazy. So far, "pineworks" solution has been a permanent one. Been about a week and have had no problems yet.
Posted on Apr 14, 2010
My canon pixma mp780 printer is giving the message "wrong cartridge". I did have a non canon ink cartridge in there, but now the cartridges are all canon, and I am still getting the "wrong cartridge"...
1. Remove the front printer cover.
2. Then take out the ink.
3. Next pull up the gray lever and take out the printer head.
4. Now go to the sink and start running the hot water. Then slowly and gently run the hot water over the metal part of the printer head. Use a soft tissue and gently clean the dry ink out.
5. Now dry the printer header with a soft cloth and wait for it to dry before placing it back into the printer.
6. Turn on your printer and see if it works now.
Oct 01, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Anyone knows how to solve error 15 on canon printer mp150?
E15 Ink cartridge is not installed. Turn off the printer. Take out the ink cartridge and then reseat it. Turn the printer back on and see if it recognizes the cartridge. If it doesn't then try another new ink cartridge. Make sure its one from Canon and not a 3rd party refurbished one. If it still gives you the error message then that means the main board in the printer is bad and you would need to replace the printer.
May 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Jun 05, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Mar 31, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma ip1300 Ink absorber is full what can i do
another solution for a quick override is to unplug the power lead from the back of the printer. With one hand hold down the power button on the printer whilst simultaneously plugging back in the power lead. When the light is back on, take your finger off the power button. You may need to press the power button once more, but this should 'override' the problem until the next time you turn your printer off.
Mar 26, 2008 | Office Equipment & Supplies
Ink tank
Users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again,
  • By replace a new ink cartridge will sure help as the partial used one would be faulty already, and if you are using Canon ink cartridge, do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge as it due to the unique feature that Canon has build on the ink cartridges not properly done, which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges.
Mar 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printer says more than one ink tank is installed
I have the exact same problem. It usually takes me quite a few times of taking the tank out and putting it back in to get the machine to comply. Any solutions?
Dec 12, 2007 | Canon PIXMA MP530 All-In-One InkJet...
CANNON PIXMA IP1300 INK CARTAGE PROBLEM
dera vicky
many problem that canon has give to us, but let me to try to give some advice for you
the trick is
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
and for the tool program i send you'll later after i receive your e-mail
just send me your email
oke
but i hope the trick can solve your problem
cropp
Oct 09, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma MP530
I am in the same situation. When 'Check Ink' comes up, the yellow cartridge blinks.  If I take it out and put it back again, the printer will work.  Then after a while on idle mode, the problem will show up again.  Pretty annoying.
WF
Sep 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
RECOGNITION OF GENUINE CANON INK CARTRIDGE
I posted the original problem. Although the cartridge was genuine I had taken it out and reinserted it as I wasn't sure I had loaded it correctly the first time. Advice from my local retailer was that this was a mistake. Canon PIXMA printers no longer recognise a cartridge once it has been removed. Solution was another new cartridge which I shan't remove until it's empty. When this second cartidge is empty I shall try the first cartridge again as it is still full and unused. It has yet to print anything! Why Canon's helpdesk couldn't help is a mystery. I conclude that Canon's printer management systems are unfriendly to users. They are friendly only to Canon. I hope my experience will help others especially those considering buying a Canon printer. dudbob
Jan 22, 2007 | Canon PIXMA iP1600 Printer
old marine
old marine
