Question about RTO Locks & Locksmithing
Can get in keypad won't take code and the light is on
Taft yl-99
How do I set up the id cards for a YL-99 Taft electronic code lock?
I have no idea but someone please tell us because we'd like to know also
Oct 18, 2014 | Locks & Locksmithing
How do I get a manual for YL88 electronic lock
Okay Guyz n' Galz...Finally I solved this by lot of iterations. I have YL-88, YL-68 and D77 Digital locks. They are all made by Yili from China with buttons placed circularly. Warning, to reset it might not work on button placed in square pattern (YL-99).
Default master code is 0123# all the locks mentioned above.
Now to reset the master code, press and hold the reset button(red) for 2-5 secs on the battery pack, and remove one battery. Release reset button. Give 5 to 10 secs. Then press and hold reset button first, put back the battery into it.
Now the lock is reset to factory default. i.e., 0123#.
Warning: Make sure the default works before you close the door and lock.
Now to apply new master code: Enter default 0123# and wait till the sound is gone and the light is still lit. Start your new code starting with '0' and end with * key (not the # key). It will beep twice. Your new master code is ready to use. Now if it does not beep twice. Try from the begining with default code.
Enjoy
Your'
Problem solver!
Jan 04, 2012 | RTO Chrome YL88 Keyless Electronic Digital...
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
How to reset codes on a yl88 keyless electronic digital door lock lost the manual and cannot work it have no emergency module
Enjoy
Your'
Problem solver!
Oct 02, 2011 | RTO Chrome YL88 Keyless Electronic Digital...
My keypad won't light up when door is locked whe you push lock won't light up green
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Wiring
hi im new to this forum but i did a little research and this is what It should be (according to Chrysler)
Left Rear
BR/LB -
BR/YL +
Right Rear
DB/BK -
DB/WT +
BR=Brown
LB=Light Blue
YL=Yellow
DB=Dark Blue
BK=Black
WT=White
May 24, 2008 | Car Audio & Video
2007 pt cruiser
hi i did a little research and this is what It should be (according to Chrysler)
Left Rear
BR/LB -
BR/YL +
Right Rear
DB/BK -
DB/WT +
BR=Brown
LB=Light Blue
YL=Yellow
DB=Dark Blue
BK=Black
WT=White
Locks & Locksmithing Logo
Top RTO Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a RTO Lock and Locksmithing Expert? Answer questions, earn points and help others
