Question about Hunter Dryers
Hunter royal oak blinking lights
I've seen other posts about people removing the watt governor on their fan to fix the blinking lights. I can't seem to find the little black box that people of have described on my fan. Where can I look? I have replaced the remote receiver already. I have tried cutting the only little black box out that I could find. It was in the light kit and turned out to not be the governor. I have since bought a new light kit to replace that one. The CFL and LED bulbs I have tried to use in the fan just cause blinking. Thanks for any help
  • 3,382 Answers
It sounds like there is a dimmer circuit involved and the low current of the LED and the electronics in the CFL do not work with standard dimmer circuits. The governor is actually a run capacitor for the motor. Removing that causes it to burn more energy and opperate an a much lower efficiency.
Posted on May 13, 2014
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Posted on Jan 02, 2010
rickead1
  • 1998 Answers
SOURCE: I would like to use 60 watt bulbs in my new
I did a little research on the part in fan, and its a watt governor! the government put this into effect in 2008. bush and obama did this. i read an article on the watt governors. and one person said his lights were flickering on and off. he just disconnected the governor and reatached the wires and the lights work great. they did this to keep the cost down thats why the watt governors. this was from a fan rep. part # on watt governor--98480-02 remove governor and reattach the wires for the light if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Posted on Dec 15, 2010
  • 122 Answers
SOURCE: My Hunter fan with light
this sounds like the remote in the fan went out the diod will burn out and cause this issue if you go in the fan by the breaker box and see the board you will see a burnt out diod you just need to replace the remote at lowes there about 45dollars good luck
Posted on Aug 04, 2011
Testimonial: "Thanks for taking the time to help me. I did not know where to go to find the part. I'll check Lowe's, as you suggest."
Hunter Fan. Lights blinking on and off. I have read that it is the light governor and I should remove it and wire direct. I need more detail. Where is the light governor and how do I wire it...
the watt governor is inside of light assembly. it is a square black box. take this out and hook it direct, white wire to white wire, black wire to red wire. and this should solve the blinking lights. good-day!
Aug 10, 2011 | Hunter 22460 52'' The Astoria Brushed...
What is a watt governor and what does it look like?
it is a small black box for the lights. if lights blink on and off, it is the watt governor causing this. just remove governor and wire lights direct. part # 98480-02. have a good day !!
Dec 29, 2010 | Hunter (25417) Ceiling Fan
Hunter 'lodge' ceiling fan w/light: all switches 'on' and light blinks???? what do I do to correct problem?
if problems with the light blinking, remove watt governor inside fan, for lights. and wire the lghts directly. this should fix problem. the watt governor is a small black box to reduce wattage on the lghts. just remove it and wire lights directly. have a good one !!
Dec 19, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a fairly new hunter ceiling fan/light. Often when we turn the light on it continuously blinks on and off. To remedy this problem we need to cycle the switch (sometimes many times). I am assuming...
on most of the hunter fans there is a watt governor in it. if problems with lights blinking, remove watt govrnor, then wire it direct without governor. governor part # 98480-02, have a good day !!
Dec 12, 2010 | Hunter (25417) Ceiling Fan
The light portion of my hunter ceiling fan is blinking. At first it started blinking, then it didn't work at all, now it is blinking again. What is wrong?
the blinking is caused by the watt governor to lights( its a small black box with slots in it ). just remove this box and wire direct. this should fix problem.
Dec 10, 2010 | Hunter (25417) Ceiling Fan
Light keeps blinking on and off just put in new bulbs that is not it how do i fix fan works fine
there is a watt governor on inside for lights. remove this governor , and rewire lights direct. this should fix problem. part #-- 98480-02 ).
Dec 10, 2010 | Hunter 52" Ceiling Fan With Light And...
When we turn on the light, the light blinks on and off really fast like a strobe light. I have checked and all the connections are correct and secure.
there is a watt governor on inside for lights. remove this governor and wire direct for lights. this should fix problem. have a good day !!
Nov 14, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a hunter ceiling fan. The motor works fine, but the light blinks on an off rapidly when switched on. The pull chain works but the light does the same thing. Do I need to replace the entire fan?
NO YOU DO NOT !! there is a little black box on inside of fan that controls the lights, its a ( watt governor ). just remove this black box and wire directly to the lights. problem should be fixed !! have a good day !! this is another goverment quick fix.
Oct 30, 2010 | Hunter Ceiling Fan Light Switch Control
I have 2 of the same Hunter Douglass ceiling fans with double light kits in my living room. Yesterday one of them started blinking the lights constantly when I tried to turn on just the lower bowl light....
if problems with blinking lights, remove watt governor on inside of fan for the lights.its a black box,white to white wire and black to red wire. and wire it direct without watt governor or black box. this should fix the problem. the part # 98480-02 for watt governor. they installed watt governors on ceiling fans to reduce light wattage.
Sep 19, 2010 | Hunter Fan/Light Wall Mount Control 27186
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
