Question about Econoco Corp Steam Butler Ii Garment Steamer - Grey
Replacement Econoco Steam Butler water bottle
When has my iron stopped steaming and heating up?
depends on how old it is, try to rinse it with a water and vinegar solution, this might help
Apr 09, 2015 | Euro Cuisine Ootoo Iron, 1500 Watt Steam...
Why is there no steam?
Plugged in? Add water? Check the fuse on the power cable.
Jul 20, 2014 | Haan Complete Multipurpose Steamer MS-30R
Why are there hard deposits in the boiler of my eurosteam iron?
Tap water contains minerals/chemicals, whether it's from a well, or from a city source. When water is heated to steaming, these minerals, precipitate out of the water and form deposits. Use some vinegar. The mild acid will help loosen the deposits... and from now on use distilled water.
Jun 10, 2014 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Doesn't steam
the hoses sometime kink when hot then get hard in the kink part once cooled down.. you may need to fin the area and warm it up to let the steam pass..
Dec 13, 2013 | Haan Complete Multipurpose Steamer MS-30R
Euro steam iron
Seems silly... but is it plugged in to a live outlet? Does it have water?
Sep 30, 2013 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Conair Lysol hand held steame
It could be broken but it could also be jammed or clogged by some dirt or water. My first answer would be to get a new one. but if you dont want to throw it away you should take it to a recyling store.i know that is getting rid of it but it is not exactly because you still remember it.
May 25, 2013 | Garment Steamers & Presses
Econoco Corp Steam Butler Ii Garment Steamer - Grey Logo
203 people viewed this question
Top Econoco Corp Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you an Econoco Corp Garment Steamer and Press Expert? Answer questions, earn points and help others
