Question about LG 22LG30 22 in. LCD HDTV
Remove base from a mn 43 lg 22inch tv
Taking the base off
2 Suggested Answers
  • 187 Answers
SOURCE: the screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
Posted on May 27, 2009
How do you remove ribbon cable connection from printed circuit board on a 43" LG TV
Just gently pull up while pressing the release tab on the connector
Jul 13, 2017 | LG Televison & Video
How to remove the Base from a Sharp LC 46D64U TV
No.
Stand or base on any model of TV should be removeable without taking the back panel. How to Remove Pedestal Stand from Your TV YouTube
Oct 31, 2016 | Sharp Televison & Video
HOw do I remove the base from a LG 32LK330 flat screen TV
Lay the tv screen facing down on something soft like your sette or bed so the base is hanging over the edge.
At the back you should see screws on the base, if not visible they will be under a cover which should prise off
Dec 31, 2013 | LG 32LK330 TV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Taking off stand from LG tv to mount on wall
I work on TVs and the amount of screws in the back is crazy.
find a place to lay the tv down on the screen, use some pads and a blanket to prevent scratching or cracking screen. your couch or bed may be a good choice, but make sure it is stable. let the stand hang over the edge with no weight on it. now look for 6-8 screws per per leg of the base. depending on the size of your tv. these are usually the larger screws on the tv and attached to the frame of the TV. remove these screws in the base and slide the base out.
your manual should also have a brief description of base removal as well. dont worry about taking out the wrong screws, you can put them back in it is not the right screw. with tv on its face, no parts will fall out. hope this helps.
Apr 08, 2009 | Televison & Video
Microsoft Wireless-G Base Station MN- 700
Just remove the router and reinstall it. it will ask you for new Base name Etc and new wirless network name with new security key codes.
Aug 20, 2008 | Microsoft Broadband Networking MN-700...
Picture problem
try to put away any electric device which is near your tv set
Nov 25, 2007 | Samsung HLN4365W 43" Rear Projection...
LG 22LG30 22 in. LCD HDTV Logo
26 people viewed this question
