Question about Mitsubishi WT-46809 46" Rear Projection Television
Wt-46809 Not coming on
Need help, with a 2-1 code
    Genius:
  • 1,694 Answers
Try hard reset==leave unplugged from AC a while.
Next--NMI==need more information!
Is this your first problem? Any symptoms before shutdown?
Posted on Oct 11, 2007
On my mitsubishi wt-46809 the error code is 2 blinks pause 2 blinks. What is this?
it is short protection and means one of the fuses for the convergence circuit is blown.
I can help with this if you want.
SD TECH
Jan 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
I have a model # WT-46809 and in comes on and within 5 seconds shuts off error code repeats 2 pause 2 pause2 over and over what do u think it is
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Oct 15, 2010 | Mitsubishi WT-46809 46" Rear Projection...
I have a Mitsubishi wt 46809 with a error code of flash flash pause flash flash
That is error code 22 which means the unit had a momentary recovery from a reset. You should unplug it for 30 minutes, then plug in and try it again. This will reset the fault and if there are no other problems the unit will work ok. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
May 07, 2010 | Mitsubishi WT-46809 46" Rear Projection...
When I turn on my tv it will shut off
Model number is WT-46809?
If set comes on for a moment and then goes off(green power light)
ON THE FRONT OF THE SET PRESS BOTH menu AND input at the same time and hold both buttons in for at least 5 seconds---then release both buttons.
Watch the power light---it should blink a two digit code---ERROR CODE---
The most common is 2 blinks, a pause and 2 blinks-----set will repeat the error code about 10 times.
If you find this error code let me know the blinks and I will tell you what it means and may be able to tell you what is needed to correct it.
SD TECH
Oct 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
electech
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 rear projection
see if the ics warm up ...out your hand on them if so they getting power.. if cold you lost a resistor or 2.
Sep 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT 46809
22 is a error code for a short protect which is triggering shutdown . Try unplugging the crt circuit boards and seeing if the fuses still blow when you press power.
Jun 22, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
2-2 code
convergance ic are bad:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Nov 02, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809
I hooked up the DTV mode good picture but no sound ? Help please
Oct 09, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
