Question about Wildgame Innovations X6c Digital Scouting Trail Camera
Model w5x will not turn on with double a batteries installed
Press blue button nothing happens
Computer comes on and I only get blue screen. Taken battery out, turned electric plug off. Hit start button 30 seconds, then plugged up electricity, started machine, still nothing happens. What other...
Another suggestion is to take the power out, remove cables and battery then press and hold the power button for 10 seconds. Then reinsert the cables and battery and turn on the pc. If the blue screen still appears, take note of the blue screen error and try to boot to safe mode with networking. If you have a recovery disc, boot it by pressing F12 repeatedly in startup to run the check disk. If did not work, then you have no choice but to reinstall the operating system...
Jun 19, 2010 | HP Pavilion tx1000z Notebook
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
My zen won't turn on. only the blue light flashes when its plugged in. the screen doesnt turn on. what does this mean thanks
Well you can try this if you still got the zen, press the reste button, dont hold just press it then hold down the power button and it will start up but mine just kept on going black fter a while so i had to put it into recovery mode by doing the following.
Hold down play untill the end
Press the reset button
Hold down the power button
Makes sure you releas the play button last
after that do Reload Firmware i think
then it will delete the firmware make sure you have this downloaded on your computer
http://support.creative.com/downloads/download.aspx?nDownloadId=10889
its the newest firmware
when you downloaded this plug in your zen into the computer and it should turn on your zen and then say Firmware problem and if it doesnt just put it into recovery mode then plug it in.
Then make sure all application are turned off like Mozzila or the Internet Explorer, then just double click on the firmware and it should fix
Feb 01, 2009 | Creative Labs ZEN Vision:M Digital Media...
Wii balance board: i press the power button but nothing happens
Ensure you have fresh AA batteries installed. Ensure that Wii Fit (or any other Balance Board using game) is fully started before pressing the power button.
And, at the risk of sounding silly, ensure that the button is facing away from the TV.
Dec 30, 2008 | Nintendo Wii Fit for Wii
Toshiba a100 laptop
Definitely try without the battery. These models are known to have a "short" problem, usually with the palm rest, which causes this failure, although it usually is more sporatic, and doesn't happen 100% of the time.
Also, can you remove all but 1 piece of memory.
Good luck, and let us know what happens.
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Light always ON!!!
hold the button and wait till the light blinks twice and it will turn off
Jan 29, 2008 | Motorola Mobility HS820 Consumer Headset
Wildgame Innovations X6c Digital Scouting Trail Camera Logo
26 people viewed this question
Top Wildgame Innovations Home Security Experts
Lawrence Oravetz
Are you a Wildgame Innovations Home Security Expert? Answer questions, earn points and help others
