Question about LG 42LC5DC 42 in. LCD Television
Not getting any signal on HDMI outputs LG 42lc5dc tv
5 Suggested Answers
  • 5 Answers
SOURCE: how to unlock lg tv 42lc5dc (input not available)
Is there a unit pluged into the AV ports, most of the new models won't show any AV until there connected
Posted on Jan 20, 2011
Mas Baz
  • 177 Answers
SOURCE: Hi, I have bought LG LCD
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Posted on Mar 21, 2011
SOURCE: hdmi wont connect to hdmi on laptop - shows lg
Hi andy838,
I see that you LG LCD HDTV is giving you a No Signal message on the Screen.
see steps Below on finding out what will show video on your LCD HDTV.
* First make sure that the HDMI cable is connected to your Laptop to the HDTV LG.
* On your TV check your remote control and look for the input or Source Button, this will help you set your TV for the HDMI connection.
* Once set, turn your Laptop on and see if the HDTV will provide Video from the Laptop to your HDTV using HDMI.
* I believe that works right, now we have video still we need to set the Audio to work from you Laptop using HDMI to your HDTV.
* On your Laptop lower right side look for your speaker icon, right click on the speaker icon then select Playback Devices.
* Once you've selected Playback Devices you will see a window showing you a list of devices and the first one on the list will be you HDMI connection right click on it and select set as default device this will make your audio work on your HDMI to your TV.
* Once audio to HDMI is set and you want to go back to your Laptop just set the speakers as the default device this will set your speakers have the Audio working again on the Laptop.
I hope that this will help you regarding your concern.
Have a nice day,
mvincentc
Posted on Apr 15, 2011
cwbymagik
  • 7 Answers
SOURCE: can't get hdmi signal from comcast dvr to LG smart tv
the type of cable you use is important. i work for dish network and i have seen cables go bad. also tv's hdmi imputs go bad as well. i would call a technitian out to look at the system, have him try a new hdmi cable and in different ports to make it work. it may be there reciever or your tv.
Posted on Mar 05, 2013
Why cant i get hdmi output
HDMI output from what? The TV??
TV's don't have HDMI outputs. They are HDMI inputs. They are a "signal goes in here" socket and not a "signal comes out here" socket
Sep 07, 2014 | Televison & Video
How can i factory reset a hotel lcd television with no factory reset opition?
You need a TV remote to select the input source from TV antenna signal.
Jul 12, 2014 | LG 42LC5DC 42 in. LCD Television
No signal from HDMI mode when I switch on the TV
HDMI is an input to the TV not an output. You select the appropriate input e.g hdmi 1, hdmi 2 on the remote. There can be a return signal the other way but the cable has to support that. Try a different hdmi cable.
May 14, 2014 | LG 42LE5500 42 in. TV
Lg 32lc7d hdmi no signal
Try another HDMI source (borrow a friend's BluRay for example} to confirm it is the TV at fault. If it still doesn't work, the TV needs a main board replacement because all the HDMI circuitry is on the main board. this usually happens after a power surge or lightning storm, and a near hit is all it takes, Sometimes, if you have a Satellite Receiver it too might be damaged on its HDMI output. So 1st try another source..IF you replace it yourself be sure to find the right board by using the TV's service # example 32LC7D-XX.XXXXXXX.. The letters where I have Xs are very important and must be matched,
Mar 30, 2014 | LG 32LC7D Television
Factory reset tv model number 42LC5DC-UA
To do a factory reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Mar 14, 2014 | LG 42LC5DC 42 in. LCD Television
Lg 42lt75 used to work with a bp630 blue ray player but now shows "No Signal".
have you tried connecting ur laptop via hdmi to tv? if it works you should probably check tv settings for hdmi, if not then it is possible that the hdmi controller from tv to have some problems, i had a similar problem with a philips tv and took it to service ending up in a total replacement of motherboard and led display
Mar 09, 2014 | Televison & Video
LG LHT854 - the HDMI output will not work. LG tv shows 'no signal'. With RCA I can use the DVD function...the HDMI cable is ok! Is the HDMI output repairable?
hdmi is an in put on these, so you'll have to use a digital optical cable,
& for more than one device you'll need a digital optical switch box...
Jan 13, 2013 | Audio Players & Recorders
How to unlock lg tv 42lc5dc (input not available)
Jan 20, 2011 | LG 42LC5DC 42 in. LCD Television
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
LG 42LC5DC 42 in. LCD Television Logo
55 people viewed this question
Computer Repairing
Computer Repairing
