Question about Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN Connection error
I have an Arris TM502G cable modem from my ISP Videotron that also provides a telephoe line jack. The fax is connected directly to it and I connect my phone to the ouput jack on the fax. I only get "Connection error". If I disconnect the phone it still is the same. If I use it in fax mode no change. If I use it in tel mode no change. If I press the On Hook Dial button i just get a not avaiulable error. If I try to cancel the job I get a Not assigned error. I dpoke to my ISP and there is no fundamental incompatibilities with their POTS line. But I don't trust any telecom here in Canada they are a bunch of crooks. I suspect they might want me to pay for a voice mailbox and an extra fee to get automatic fax detection even if their tech support says that I don't have to pay for these services to make it work. I have seen the top management lying to their own employees to increase their revenues. Here in Canada deregulation gave the telecom total power over the apathic and politically stupid canadians. Sorry but my theory is not proven yet, What I can prove though is that they steal the public :) Thanks for your help :) Michel
  • 10 Answers
Might be a few years late, but I had the exact same problem, and the guest in Solution 1 fixed it for me. He was right when he said connection error was a networking issue, which I've known all along. And then it dawned on me. I set it up so outgoing faxes are also emailed to me for backup storage of sent faxes. I disabled email forwarding for incoming and outgoing faxes and it immediately worked correctly. I'm assuming I have a different problem with my email settings, but if someone else has this issue, my experience may help them out. God knows, "Jason from Connecticut" with the really strong indian accent is never going to help you get it working correctly.
Posted on Sep 08, 2010
Not sure about you having a POTS line there. If you have the phone line coming out of a cable modem your line must be VoIP.
Anyway, this seems to have nothing to do with your telephone line since the FAX must try to dial even when you don't have a phone cord connected at all.
"Connection error" is referred on the manual as a message for network problems, not FAX.
  If your phone is connected to the EXT port of the CLX-3160FN and you can make calls from it normally, then your connections are made right. You should definitely go for the nearest service center. I know, I know, it's over 20 Kg heavy...
Posted on Nov 27, 2007
Somehow it was just lost in space. I
One thing usefull is if you press "menu 1934 menu" you can select between the user menu and tech menu where you have a better control. It is difficult to activate, you might need a few trials before catching it.
I wanted to print to fax directly and I tried to add windows components and my legitimate win xp pro SP2 original CD is not recognized. The CD is fine, no scratches and I know it works. So I can't add anything, FAX or services or protocols.
I guess Microsoft wants to sell Vista.
Posted on Oct 20, 2007
  • 161 Answers
Let's isolate the problem: disconnect your modem from the wall outlet and connect the Samsung unit DIRECTLY to the wall using the LINE connector (not the TEL connector). If the unit is ok and your telephone line is clear, you should hear the calling tone when the HOOK/DIAL button is pressed. If it works, your theory might be correct, or you were incorrectly connecting the unit to the TEL connector (use the LINE conector instead). After the problem is solved, leave the Samsung unit connected to the wall and connect all others peripherals after it.
If the unit is not working after this test, take it to an authorize service center to have the modem (and maybe the power supply) board replaced.
How do you find a WEP Key for a Arris Model TM502G
The TM502G is an MTA (Cablemodem with 2-line phone adapter)
it does not have a router wired or wireless therefore there is no WEP Key to find
Sep 29, 2010 | Arris Touchstone 450a (CM450) Modem
Spl-c error - including corrupted data (printer Samsung)
SPL-C -Incomplete Session by time out
Position : 0xddde (56798)
System : src/os_hook
Line :1646
Version : SPL-C 5.35 11-20-2007
Any one can help me how to fix this Error please.
Oct 15, 2009 | Samsung CLX 3160fn All-In-One Printer
I am trying to use the fax facility on my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Jan 26, 2009 | Arris Touchstone 450a (CM450) Modem
I have arris tm502g modem n want to hook up 2nd pc wont work
You need a router or network switch to share the single connection from this cable modem. Wireless router if you're so inclined. Comcast is about to jack the rental rate for that modem from $3.50 to $5 on January 1, at least in Atlanta.
Jan 07, 2009 | Computers & Internet
CLX-3160FN SAMSUNG Printer/Scanner/Fax
Replace your USB cable with a good quality, thick USB cable that does not exceed 10ft. Let me know if the problem persists.
Be blessed.
Aug 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Black lines across page
are black lines appearing on paper after printing from computer or when a fax is sent or recieved or both?
Jan 15, 2008 | Samsung CLX 3160fn All-In-One Printer
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
629 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
