Question about Philips Magnavox 27MS343S 27" TV
Phillips 21pt2324/71 won't power on after power outage
    Problem Solver:
  • 18 Answers
First check the power supply of your TV,multimeter the export voltage of power supply.if it is defective you can replace it.
if not you need check main boards,and inverter boards
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Posted on Dec 09, 2013
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
Air conditioner won't come on after power outage
i would suggest looking for a hidden reset button on the unit or check any fuses/trips connected with it.
May 30, 2012 | Heating & Cooling
Hello!WE had recent power outage ,now door opener won't work.unit has power lights come on when remote pad pressed,but nodoor action?thank you
Along with the power outage you probably also had a power surge. You need to pull the logic board and check the printed circuit board for burnt or missing traces. Unplug the unit first.
Sep 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hello i hava aq-see qt426 surveillance system and after a power outage it won't boot, keeps rebooting and freezes on 'system initializing" screen. do i have to format the HD or it could be...
you need to format the HD. The sudden power outage is the reason the unit is freezing. As a matter of fact, the HD is the cause of the freeze. The HD has not been able to recover from the sudden power outage.
Format the HD and hopefully the unit should be back to normal.
But if unit is not in order after formatting the HD, please let me know for further direction.
Good luck.
Jun 23, 2011 | QPS Q see QT426 Video Surveillance System
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
After Power outage - picture is larger than screen
This TV also should have similar facility like 19" Tv. Try the menu, it may be in different name or classification. I do not suspect circuit fault. If you can access service menu code you can try. Better take assistance from service center. If you access service menu, do not for get to note down the values in each and every step.
Apr 30, 2010 | Philips 19PR19 19" TV
I have a Magnavox TV/DVD and i recently had a power outage. The power came back on and turned on the TV and the color of the TV screen is a purple or green tint. There is only a tiny circle about 1 inch in...
Remove the the plug from the wall socket(power) plug it back after five minutes. If the power outage was caused by lightning, then it is most likely static on the screen.
Regards
Phillip
Sep 12, 2009 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
