Question about NComputing L300 Terminal Computer PC Desktop
TRY crt+shift-end simultan in device setup - NComputing L300 Terminal Computer PC Desktop
Need help love you tube music please help me forgot password
Open a command prompt after your PC reboots and resumes setup.
- In Windows 2000, wait until the PC begins registering components and then press the "Shift + F10" keys simultaneously.
- In Windows XP, watch the bottom left-hand side of your screen until you see a progress bar that reads "Installing devices" and then press the "Shift" and "F10" keys together. This will open a terminal window.
or you can use the window CD,this modify the BIOS in the BOOT
God bless you
May 24, 2013 | Dell Inspiron 530 Desktop Computer
Connecting dvd
First, are you sure the cable is good? can you try it somewhere else? Second make sure your DVD is setup to output via component and the TV is using the input your connecting to.
Jun 01, 2008 | Televison & Video
Not playing NTSC DVDs
I can see if there is an unlock code for your device
Apr 21, 2008 | Yamaha DVR-S150 DVD Player
Bkackbery reset codes
Here are some of the BB rest codes.
Soft ResetIf you can't sync your BlackBerry with your PC (device not detected), then you can make use of the following key combination to perform a soft reset:
  • Press the following keys simultaneously: ALT+DELETE+RIGHT SHIFT.
  • The screen will go blank and from there let the device start normally.
Hard Reset
  • You can use a hard reset when your applications/device are not working properly.
  • This is achieved using the same key combination as above:
    • ALT+DELETE+RIGHT SHIFT.
  • But this time you will have to use it twice.
  • On the first attempt the Blackberry screen will turn blank and will light up.
  • Upon this use the same key combination again (ALT+DELETE+RIGHT SHIFT.), you should get a blank screen followed by an hour glass.
  • Let the device boot normally and it should be OK.
Feb 25, 2013 | Cell Phones
To setup digital
Setup codes for sansui are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 16, 2012 | Sansui 27" TV
Letter between c and b wont work! its the paste code key also and I dont recall using it to paste anything Whmat's your problem?
Of course, it wont work because you used a wrong short cut key. The correct short cut command for copying is press the control C simultaneously then for pasting it, it should control V simultaneously. Try it again using the right short cut command. Good luck!
Sep 20, 2011 | Microsoft Comfort Curve 2000 Keyboard
I would like to know the code for my dvd player its a RCA please
Hello
Setup code for RCA with Philips SRP2003/27 is:
2351
[1] Make sure the receiving device is able to
respond. E.g. when you try to repair the Play
key for your DVD player, make sure to insert
a DVD into the DVD player otherwise the
Play key is not able to function.
[2] Select the device
that you wish to
operate (e.g. DVD).
Press the (DVD) device
selection key to
select DVD.
[3] Keep keys (1 & 4) and
pressed
simultaneously for 5
seconds
The red Setup
light lights
up. The remote control is now in setup
mode.
8 EN
[4] Press and hold the key that does not
function and immediately release it when
the device responds.
* If the key still does not function as expected,
try pressing it again for a longer period of
time.
[5] Press the (DVD) device
selection key twice
to save your settings
and exit setup
mode.
When no key
is pressed for 5 minutes or more, the
remote control will exit setup mode,
automatically saving all your settings.
OK.
Aug 15, 2011 | Philips SRP2003/27 Remote Control
How to reset a sidekick 08 when the screen is on lock mode
Press the Jump button to access the Jump screen.
Select to Menu,Settings,System Info.
Press Menu + Shift + X simultaneously.
This prompts you to erase Flash Memory.
Select Yes.
From the same screen, press Menu + Shift + R simultaneously.
This prompts you to erase Sign-In Information.
Select Yes.
Insert a paper clip in the reset hole while holding down the Power button
The device vibrates if done correctly.
You are now restored back to the original factory settings
Mar 03, 2011 | Cameras
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
NComputing L300 Terminal Computer PC Desktop Logo
37 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
