Question about HP Officejet Pro 8600
Object stuck in feeder
There is an object stuck in the feeder. Is there a way to take apart the auto feed
  • 52 Answers
Remove the feeder tray and using your fingers (printer turned off and unplugged), rotate the rollers by hand the opposite way that they normally travel. So in other words, 'pull' the roller towards you. It may help if you have the machine upside-down too, so that the dropped item can fall out if the lid is open.
Posted on Nov 26, 2013
Paper jam I've cleaned sprayed,etc must be something I can't see w/o going deeper. How do I remove cover to get to paper rollers in MX340
Removing the covers is not the answer. Most jams on rear feed printers/faxes are due to some object falling in the sheet feeder. When you pull the paper back out (Very slowly) of the sheet feeder after it has jammed , you will see a nick in the paper. This is because the paper is hitting something and cant get past it. put the paper back in the sheet feeder and the nick will indicate where the object is. Find a large paper clip and unwind it and bend the top of it to 90 degrees. use this to hook the object out and then tip the printer upside down and watch it fall out. Good luck
Dec 11, 2016 | Canon PIXMA MX340 Wireless Office...
How to disassemble a Kodak ESP C110 printer?
Hello Edward,
There really is no reason to take it apart fully as the printer is showing classic signs of a paper jam. Usually it is a small piece of paper that has torn off and is lodged in the printer's paper path, it also could be something small such as a paper clip. Yours obviously is located on the side that the crease appears. The paper feeds in and then it hits the stuck object, then jams. Look very carefully at the leading edge of the paper near the crease and it may show the exact location of the foreign object. in the paper path. Remove the object and you should be all set!
Good Luck!
Rich Lilja
Mar 01, 2015 | Kodak Office Equipment & Supplies
My mp250 is taking the paper in sideways and I have looked and the rollers do work. What could be the cause and am I able to fix this problem myself?
oh dear, Never spray lubricant or anything other than air into a printer. I presume when you say "sideways" you mean "skewed".
If so then you have an object in the paper path that will cause this.
Let the machine try to feed the paper then when it jams VERY SLOWLY pull it back out. No look at the leading edge of the paper for a nick in it. The nick is caused by the paper hitting an object. Now lay the paper on top of the paper that is in the feeder. Look at where the nick is. Now refer this to the machine so you are looking into the machine in the position of where the nick is. Shine a torch into the feeder and you should hopefully see the foreign object and try to remove it with an opened paper clip bent into a "L" shape.
Good luck.
Nov 29, 2014 | Canon Pixma Mp250 Printer
Paper doesn't feed
Hi, The problem could be an object inside the Auto document feeder that could be blocking the path of the paper or preventing the feed roller from feeding the paper. You can try the following, Turn off the printer, unplug it from the power cord, then remove the paper and then turn the printer upside down and shake it a little bit, sometimes this will help remove any objects inside the printer.
Feb 05, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper will not feed into printer, even with hand pushing on paper. rollers do not grab the paper.
Feeder is jammed
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 07, 2009 | Canon PC-980 Color Copier
Hi, My printer will not feed-in the paper and will not print, also the laptop is not asking printer to print
Oct 05, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Unable to feed paper
Sep 06, 2009 | Canon Pixma iP4500 InkJet Printer
Shreeder Feeder jammed , appears cleared, makes a humming noise when attempting to feed paper and a similar noise when hitting the reverse button. Help please. Thank you.
It could be one of two problems and they are both usually caused by over feeding. Either the tooth rollers have junped out of their sockets or they are jammed tight with paper which would cause the first to happen also. There are safety switches but unplug the unit any way. Get on the output side of the shreeder and start pulling paper or remove the metal object that was dropped into its throat. Hopefully, you won't have to take it apart to put the rollers back into their sockets.
May 28, 2009 | Office Equipment & Supplies
HP Officejet Pro 8600 Logo
37 people viewed this question
Seeker5211
Seeker5211
