Question about Panasonic Microwave Ovens
NN-SN778 starts cooking and then stops after 2-3 seconds
maklean
  • 1665 Answers
SOURCE: Panasonic Model NN-T994SF runs for
http://www.repairclinic.com/0088_6_1.asp
Posted on Apr 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave shuts off after 2 seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer (above) to get it fixed free.
Posted on Jan 03, 2009
SOURCE: Panasonic NN-S262SF stops cooking after 3 seconds
inverter problem the transistor 1M30D is shorted
Posted on Jan 07, 2009
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Brand new panasonic nn-ct776. When using microwave
If it stops after 7 seconds, it has a problem with the inverter.
Plus, since it's new (less than one year old), it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find an authorized Panasonic servicer here.
Posted on Aug 09, 2009
Panasonic microwave oven nn h965wfx
either your magnatron is bad or hopely it could be your high or low heat sensor
Oct 13, 2013 | Microwave Ovens
My panasonic microwave NN-S954WF will run a few seconds and then stop. What should I check?
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops at 2-3 seconds, see if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Nov 16, 2011 | Panasonic NN-S954WF Microwave Oven
Panasonic NN-S254BF microwave oven runs for 2-3 seconds and then shuts off'
See if this describes what's happening:
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 31, 2010 | Panasonic NN-S254BF Microwave Oven
NN-C980W Microwave start and stop after 2 seconds.
H!, its either you have a defective magnetron, hv transformer or a leaky capacitor.
Sep 15, 2009 | Microwave Ovens
Purchased a panasonic NN-H965 microwave and yesterday when using it, it started making the following noise: upon starting, the unit works for 3 seconds with funny noises and then it stops. There used to be...
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Aug 26, 2009 | Panasonic NN-H965 Microwave Oven
Sarts and stops itself in 2-3 seconds
Aug 08, 2009 | Panasonic NN-H504WF Microwave Oven
Oven shuts off on cook after about 2 seconds
Your actual model number is located on a tag around the control panel frame, door or below the cooking cavity.
Jan 12, 2009 | Panasonic NN-T654SF Microwave Oven
May 28, 2008 | Panasonic NN-S262SF Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
