Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Ice maker not working in kenmore 106.76236402
fanny
  • 146 Answers
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Posted on Nov 03, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
carputers
  • 255 Answers
SOURCE: kenmore gsi-23 ice maker not working
is the water line hooked up to the unit ?
Posted on Sep 24, 2009
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
The ice maker has stopped working, the motor is co...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
May 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
heatman101
fdfdfs43
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working, but water is still working
heatman101
dhghdg
Dec 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE MAKER NOT WORKING
heatman101
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator ice maker stopped working
heatman101
mnnmbnm
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
