Napatech looking for 4.22.0 software for napatech nt4e card
Cannot open Wave Device for recording. Are you sure your audio card supports the currently specified sample rate and/or bit resolution?
It's basically saying that your inbuilt sound card might not be compatible with the software. Check the software specifications and then look at your sound card specifications. You can also select a different bit rate under the recording options in the software. For example many MP3 files are recorded at 320, but you can reduce it to say 128. This might allow the an older type sound card to work with the software.
May 21, 2016 | Steinberg Media Technologies WaveLab...
Have a GE x500 camera. Sometimes my pictures come out white or just missing on the memory card. This will happen with several in a row. What is this and how do i fix it?
All your pictures are still stored on the memory card of camera.You can recover lost pictures from memory card with photo recovery software.
1.Stop using this memory card to avoid overwritting your pictures by new ones.
2.Insert the card into a card reader.Connect it with your computer.
2.Download a photo recovery software.Recommend this photo recovery software: Photo Recovery Software for Windows users
3.Install the program and scan your memory card to look for lost pictures.It shows you the thumbnails of your pictures.
Jul 28, 2012 | GE X500 Digital Camera
I need the driver for the dell silicon image orion add2-n dual pad x16 dvi video card. its installed in an hp compaq
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
if this package is not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 09, 2011 | Dell /Silicon Image Orion DVI-I ADD2-R...
How to install flash player n70 phone?
Download the Flashlite software. You can get it easily by searching in google.
Connect you phone with pc via bluetooth or a USB cable.
Trasnfer the Flashlite software to the root directory (c:\) of your phone or to the memory card (e:\).
From tools menu of your phone open file manager.
Open by default it will look in your phone memory. If you saved the software to your memory card move the right navigation key to select your memory card.
Look for the software file.
Open it and install it.
If you need any detail discription please feel free to write back.
Thank you for choosing Fixya
Jun 23, 2010 | Nokia N70 Cellular Phone
Just purchased an R4i for a DSi and I get a red ?MENU message. How can it get it working?
I spent hours on this one and finally worked it out. I have four kids and the ordeal started when I ordered two R4 cards and they turned out to be different, so I found out lots.
Odds are, you have bought a clone R4 card, not the genuine thing. If it is genuine, you can download the latest software from www.r4ds.cn. If that doesn't work, you more than likely have a clone.
The genuine R4 card uses encrypted software, so you will never get it to work with the genunine download. Just a well all the clone manufacturers have clone sites with clone software, the trick is to know which one you have and what can work. Here is what I discovered.
Turn the R$ card over and look at green printed circuit board just above the electronic contacts. You may see some white printing.
One of my cards says "R4-SDHC". This means that the R4 card can take a high capacity SD card. There are any number of versions of the software available, try www.r4sdhc.com. At the time this was written, version 1.32 worked just fine for my card.
The other card says "ROHS CARD-7A". This is not a high capacity card and no software will work with an SD card with higher than 2GB memory. So if you are trying with a 4GB card, like I was, it won't work. For this one, I switched to a 2GB Micro SD card and downloaded "r4team v 1.19" from www.linfoxdomain.com and it worked fine.
If the above software downloads don't work, there are a stack available on www.linfoxdomain.com under the Nintendo DS tab, so go with trial and error, and you should eventually get there. Note that It took a few goes with the first card before I found v 1.32 and got there.
So good luck, I feel like I know so much more now.
Jan 16, 2010 | Nintendo DSi Matte Blue Console
I need to get the Card design software for my Fargo Persona C25 ID Card Printer. I can't seem to find it anywhere.
if you are looking for card design software, we can sell you software. Fargo does not offer free software for the C25 unit.
Mar 09, 2009 | Fargo Persona C25 Thermal Printer
Sound card
Hi kamis_elsawy,
Without knowing what your sound card looks like, or understanding how to identfy a card, you can download a program that if the card is installed on your computer, the software will tell you what the card is. You can find this free software HERE.
Good Luck
Mark
Jan 06, 2009 | Computers & Internet
Aver media tv tuner card....helpppppp
First things First:
1) what is the real problemyou have?
2) if is a TV tunner, verify the brand, and look for software or generic software for TV TUNNERS. then install and run again. it is suppose to have a support page for any problem.
look.:
http://www.aver.com/mpd/support/download/download.html
Mar 21, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
