Dav dz151kb COMO SE PUEDE DESBLOQUEAR YA QUE EN LA PANTALLA SOLAMENTE APARECE PROTECTOR Y YA NO HACE NADA MAS
SOURCE: manual
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ this site has in Espaniol, download and scroll through ENGLISH. Spainish manual comes after English
Posted on Aug 27, 2008
SOURCE: THE DVD no WORKING
ya le limpiaste el lente del laser
Posted on Aug 22, 2009
donzaca
  • 273 Answers
SOURCE: porque en la pantalla pequeña de la
actualisar you have your camera software can be hopefully help with virus
Posted on Dec 05, 2010
  • 22 Answers
SOURCE: aparece un ipod triste en
eso pasa cuando la unidad de disco duro ( hard drive) lla no funciona/ sirve. Puedes comprar uno disco duro nuevo e instalarlo tu mismo. pero no vale la pena pagar para arreglarlo por que cobran muy caro
Posted on Dec 29, 2010
welcomejee
  • 10594 Answers
SOURCE: I have Home Theater Sony DAV- DZ151Kb. Display
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Jan 14, 2011
Testimonial: "Thanks for the support, it really is a very good recommendation I will check if you are getting voltage to the integrated and review the external components. "
Zte n9511 la pantaya esta negray no se puede ber nada
Lo primero seria buscar en Google "Como hacer ZTE N9511 nuevo de f?brica". Si puedes ver videos mucho mejor. Esto lo que hace es entrar en una secci?n del celular conocida como recobrar, o recovery en Ingl?s. Si el celular prende, y logras acceder al recovery, que se pueda ver la pantalla, entonces puede ser una falla del SO (Sistema Operativo). Mediante el recovery puedes hacer nuevo el celular como si fuera de f?brica, o sea, como cuando se compra nuevo de la tienda. Esto repara el SO, haciendo que el celular vuelva a trabajar.
Este video es el que mas se asemeja a tu modelo.
Apr 02, 2015 | ZTE Cell Phones
CONTROL REMOTO NUEVO NO PUEDO PROGRAMARLO AL RECIBIDOR DISH.
Hola Jose, mi nombre es Kimberly y formo parte del departamento Social Media de DISH. Es my placer asistirle. Para que el control funcione, debera de programarlo al receptor. Para programar el control de DISH Network a su recibidor puede seguir los siguientes pasos: primero debe de accesar la pantalla de System Info esto lo puede lograr con tan solo oprimir el boton que dice System Info enfrente de su recibidor. Una vez este la pantalla de System Info tome su control y oprima el boton se Satellite por 5 segundos hasta que todos los demas botones se iluminen en rojo una vez esto suceda oprima el numero 8 seguido por el signo de numero (#) y despues boton de Record 3 veces. El control deberia de funcionar, puede intentar su funcion oprimiendo el boton de Cancel esto deberia de llevarlo de regreso a su programacion. Puede usar este link que tambien le puede servir mucho en como arreglar su control y los pasos seguir http://www.dishnetwork.com/SupportSection/remote-control Si tiene preguntas adicionales sientase libre de contactarme a: kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L.C
Dec 10, 2013 | DISH Network IR Remote Control
Tengo un acer aspire 5100 bl51 cuando la enciendo en la pantalla no aparece nada y esta toda negra no se que pudo suceder estaba descargando videos y de pronto se oscurecio la pantalla se escucho un...
Desconecta la bateria principal y Desolda una bateria chiquita que trae en la tarjeta madre (Posiblemente este debajo de la tarjeta Inalambrica).
Luego manten precionado el boton de encendido durante unos 10 segundos. Luego conecta todo y Listo. Ya que compruebes que te da Video le soldas nuevamente la bateria. Eso es Todo
Aug 30, 2012 | Computers & Internet
Hola.. tengo una camioneta dodge caravan 99, 6 cilindros, 3.0, automatica, desde hace tiempo sentia que al momento de meter los cambios se sentia un tiron, pero lo deje y hoy estuvo marchando como de...
hola pues tengo una grand caravan 99 y la palanca de cambio de la caja (automatica) ya no da mas se quedo en D y ya no se puede encender devido a ella que podrian orientarme ?
Jul 07, 2012 | 1999 Dodge Caravan
A CABO DE COMPRAR UNA ACER ONE MINI. PRENDE LA COMPUTADORA PERO LA PANTALLA SE QUEDA EN NEGRO, HACE UN RUIDO COMO SI LEYERA EL DISCO DURO PRO NO APARECE NADA. QUE ES LO QUE PUEDO HACER
puede hacer la bateria que esta baja, tratar de cargarla primero sacale la batteria luego poner sela y cargar y prenderla de nuevo haver si funciona
Feb 19, 2011 | Acer Aspire One PC Notebook
Mi control de dish no quiere hacer nada quien me ayuda
Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Lamento escuchar que este teniendo un problema con su control de DISH Network, seria un placer asistirle proveyendole informacion que le sea de uso para resulusionar el problema. Si el control no esta haciendo nada primeramente debe asegurarse de que el control este en el modo de SAT significando que cualquier boton que oprima el control el boton de SAT en la parte de arriba se debe encender en rojo. Si ningun boton se enciende en rojo puede intentar poner baterias nuevas en su control, si no funciona significa que el control no sirve necesitaria uno nuevo, si el boton de SAT se prende en rojo puede intentar reprogramar el control a su recibidor. Para hacer esto tiene que accesar la pantalla de System Info en su televisor, puede hacer esto oprimiendo el boton de Sys Info enfrente del recibidor. Despues en el control va a oprimir el boton de SAT hasta que los demas se enciendan rojos cuando vea que se encienden rojos ingrese un numero entre 1-15 seguido por el signo de numero (#) y el boton de record una vez. Trate el control deberis funcionar. Tambien puede entrar a nuestra pagina web http://www.dishnetwork.com/SupportSection/remote-control aqui encuentra ayuda en como arreglar el control y el procedimiento. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH gracias espero esto le ayude.
Feb 09, 2011 | DISH Network IR Remote Control
Esta prendida la tele y no se mira nada que hago para que funcione
Hola mi nombre es Mayra Diaz con DISH Network. Muchas disculpas que est? teniendo estos problemas con el sistema. Por favor, me puede describir un poco m?s de lo que aparece en su pantalla. Aparece un mensaje usualmente puede que aparezca un n?mero de tres dijitos ala mano derecha de la pantalla. Si no ay ning?n numero si me puede dar mas detalles del problema q est? teniendo con mucho gusto le ayudar? con su problema.
Jan 01, 2011 | DISH Network IR Remote Control
Pantalla negra VAIO VGN-UX280P
Por lo que comentas, el problema debe haber estado en algun contacto de la pantalla que no permitia su correcto funcionamiento. El invertidor or inverter posiblemente no estaba funcionando bien. A este punto puedes si luego de cambiar los LCD el viejo volvio a funcionar es posible que el problema este alli. Puedes enviar tus LCD screen para que sean revisados y tal vez reparados para evitar un gasto mayor. Te recomiendo que sino tienes experiencia en este campo lleves tu equipo al servicio especializado.
Nov 06, 2008 | Sony VAIO VGN-UX280P Notebook
Informacion
El problema es que tienes puesto en arranque automatico esta aplicación. Mi recomendación es que salgas de ella, te vayas al explorador de archivos, mi dispositivo, windows, inicio y quites esa aplicación del menú de inicio. Si no puedes hacerlo por que no puedes salir del programa, prueba a conectar el terminal a la cuna y lo haces desde windows.
Oct 08, 2007 | Symbol MC50 Pocket PC
 Grubhead
Grubhead
