Question about Simplicity 5000 Series Secondary Filter SF5-2
Simplicity 5000 sentry iii vacuum belt
How do i change the belt on my simplicity sentry iii vacuum-- I think I'm doing it right, but the belts keep breaking after just a few uses
4 Suggested Answers
SOURCE: How to replace the belt.
Instructions are in the manual, free online here:
http://simplicityvac.com/about-my-simplicity/manuals/7000.pdf
Short version: slide the two retaining clips to the center and remove the bottom plate. There's a C-shaped retaining clip at the right end of the roller tray. Remove the clip and lift the roller out. Thread the old belt from around the motor drive shaft, thread the new one in, put it around the roller and replace the roller - belt will stretch enough to let you do this. Put the C-clip back in, replace the bottom plate and go.
Posted on Jul 16, 2009
  • 569 Answers
SOURCE: simplicity freedom vacuum has a burnt rubber smell
If the belt is continually wearing out I would think that the brush cylinder is not free to rotate. Take the belt off and ensure that the brush cylinder moves freely. If is does not, then you need to investigate why - probably something wound round it that has jammed it.
Posted on Apr 06, 2010
  • 5159 Answers
SOURCE: Simplicity F3500-- how do I
To change the belt on the Simplicity F3500, unplug the vacuum and turn it upside down. There are two tabs (one on each side) behind the beater bar that hold the cover on the vacuum. Press these tabs inward and lift the bottom plate away from the unit.
Then remove the brushroll and the worn or broken belt from the pulley on the side of the brush roll and the drive shaft. Loop the new belt over the driveshaft and the brushroll. Replace the brushroll in the housing and turn it by hand. Make sure that the belt is seated on the driveshaft and pulley with no twists. Also check that all of the rotating parts will move.
Then put the bottom cover back on by aligning the back hinges and then pressing the plate down until both sides click.
For pictures of the cover removal process, look at page 15 in the manual. The direct link is http://www.simplicityvac.com/about-my-simplicity/manuals/FreedomManual_Update0803.pdf . Most Simplicity vacuum manuals are available at their support site: http://www.simplicityvac.com/about-my-simplicity/manuals/ .
I hope this helps.
Posted on Aug 11, 2011
HOW TO CANGE BELT ON SIMPLICITY 9.8 VACUUM
This is pretty easy. Turn vac upside down, remove brush cover, brush with belt on it pops out on each side. You must get the exact replacement belt so take your model number and any other numbers to vacuum repair shop. The belt around brush then around motor spindle, replace brush and cover.
Jun 20, 2014 | Simplicity Vacuums
Belt replacement on simplicity synergy x9 series
Your simplicity has a lifetime belt. It has a sensor to shut the direct air motor off if something restricts the brushroll from from turning. You may save money in the long run by taking it to a simplicity or Riccar vacuum dealer.
Mar 22, 2014 | Simplicity 7250 Deluxe Vacuum
I have a simplicity 7350 vacuum. The belt and roller have recently been replaced. It runs fine on floor mode and has no problems with suction. When I put the vacuum in carpet mode, I do not hear the motor...
the motor spins around a steel shaft that sticks out on one end, and the belt is driven by that shaft, belts are easily damaged and broken, meaning roller wont spin. Often a burning smell of rubber is noticed after motor shaft spins on stuck belt. cause is always hair./string/something at the three contact points. motor shaft and belt, roller and vacuum body become clogged. become familiar with taking cover off roller/belt, and cleaning Checking moving parts roller/belt come out easily and simple to clean...keep spare belts.
Mar 10, 2014 | Vacuums
My simplicity 7200 does not have vacuum. Air comes out the front post filter area
If air is coming out of the filter air has to be going in through the suction hose but it may be restricted with a clog. Replace the bag and both filters. If it's been over six months since the belt has been changed start by changing the belt. Most of the vacuums brought to my store with the customer stating "it has no suction" actually have great suction but no agitation from the brush roll. If the belt is not turning the brush roll fast enough when vacuuming the carpets it will not even pickup lint and hair.
Oct 28, 2013 | Simplicity 7850 Premier Bagged Canister...
Simplicity F3500-- how do I get the bottom off to change the belt?
I hope this helps.
Aug 11, 2011 | Simplicity 7250 Deluxe Vacuum
Simplicity freedom vacuum has a burnt rubber smell
Apr 06, 2010 | Simplicity 7250 Deluxe Vacuum
Apr 03, 2009 | Simplicity 7250 Deluxe Vacuum
REPLACING BELT KIRBY CLASSIC III
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=806061
Posted by JETALBOT on July 19, 2008
I CAN'T REPLACE THE BELT ON THE CLASSIC III (KIRBY). CAN YOU HELP ME? ELAINE
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 19, 2008 | Kirby Heritage II Vacuum
Changing the belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=83009&thid=695737
Changing the belt
Posted by cbgolba on Jun 22, 2008
My husband changed the belt on our vacuum, now the metal frame doesn't fit back on the bottom. Also, there is a small metal clip that we don't know where it belongs.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You should check on the owner’s manual to see how it goes together or call the Simplicity customer service line listed below to see what goes where. It’s been awhile since I have worked on a simplicity vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://simplicityvacuums.com/ Customer Service 1-888-9-Simply
Go Ahead. Use Us.
Jun 22, 2008 | Simplicity 7850 Premier Bagged Canister...
Simplicity 5000 Series Secondary Filter SF5-2 Logo
188 people viewed this question
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
