Question about Siemens WXLP1460 Front Load
Siemens washing machine type WLM 40 with F12 flashing on function display
What problem on machine does this indicate please
5 Suggested Answers
SOURCE: my siemens washing machine does not spin but the
Hi, I have a Siemens WXL166AGB washing machine that has started jolting violently when on the spin cycle, as if something is out of balance, never getting fully up to speed. Subequently it cuts short the spin cycle and leaves the clothes wet. Any idea what it could be. Thank you, Phil Vanes
Posted on Dec 10, 2009
  • 12 Answers
SOURCE: HOW DO I CHANGE THE LANGUAGE DISPLAY ON SIEMENS
download the instruction manual here http://manuals-market.com/search.php?creference=Dtr37d6tre,hope that helps.
Posted on Feb 28, 2010
  • 154 Answers
SOURCE: I have a siemens WM14S794GB washing machine and F23 is flashing
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
Posted on Jun 22, 2010
  • 414 Answers
SOURCE: siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
Posted on Nov 26, 2011
Dear my washing machine is product from italy made siemens wash and dry its showing E14 errorr please advise me what i can atcvally
Laundry appliances use many different codes depending upon age and origin. Faults that can be dealt with by the user are normally listed in the instruction book.
Link to instruction manual download Flashing LEDs or displays frequently indicate door not closed, low water pressure or a blockage in the drain pump, drain hose or your drainage system.
Dec 09, 2013 | Siemens Washing Machines
Hotpoint WF860 1600 spin machine keeps flashing F12. How can I solve it please???
Hi
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps
Also Error code F12 is indicating a communications error between cards; Error code F12 is indicating a communications error between cards, this can be caused by one of several things. A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is an electrical problem as opposed to a mechanical one.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | Hotpoint Ultima WF860 Front Load Washer
Siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Sep 18, 2010 | Siemens WFXD8400UC Front Load Washer
Machine wont work and flashes f12 on function display
F12 is classed as a communiction error.
Either faulty connections or electronic panel
May 27, 2009 | Hotpoint Ultima WD72 Front Load...
f12 is a communication error between the circuit boards. engineer job. if the machine is less than 5 years old the parts are free but the callout +repair's about £100 from hotpoint.
Jan 25, 2009 | Hotpoint Ultima WD72 Front Load...
Siemens XLP 1400 stops with F12
The manual says that it means there's water in the base pan because the apliance is leaking and you should callCustomer Service.
I cleaned the filter and then put the machine onto its Empty cycle. After that it worked.
Oct 19, 2008 | Siemens WXLP1460 Front Load
F12 Error
what is F12 error code on a siemans wxlp1400 and how do i cure the fault, cheers
Dec 29, 2007 | Siemens WXLP1460 Front Load
Flashing F12 on display
F12 is either the motor, or eprom chip on pcb. Most likely to be motor
Jul 09, 2007 | Neff W5340X0 Washer
Siemens WXLP1460 Front Load Logo
193 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
