Goodman Problems I just installed a Goodman Model HKSC15XBAA electrical unit and can not get it to run, I hear a hum but the burners will not fire.
  • 5 Answers
SOURCE: Newly installed Goodman GPG13 gas/electric
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Posted on Sep 22, 2008
  • 124 Answers
SOURCE: Goodman U-30 Furnace
observe the sequence of operation. stat calls for heat and sends a signal, to furnace. check for 24 volts to common and white wire at furnace.first the forced draft motor starts and should have 120 volts to the plug it attaches to. after forced draft motor starts the pressure or vacuum switch closes should show no 24 volt when checked across terminals. shortly after the ignitor glows and shortly after click the main gas valve opens and main burners fire. shortly after the indoor fan comes on and hot air blows into the ductwork. follow the chain of events to see what doesnt happen and it is a clue to whats broke. maybe start by switching fan switch on stat to on. if fan comes on you have high and low voltage thereby eliminating the stat power and transformer as a problem. if you can see the ignitor look for it to be cracked . look close dont touch any part of it .it is powered by 120 volts when energized from board. dont forget when you take the door off there is no power to the furnace so be prepared to tape the safety switch closed when you are diagnosing.
Posted on Oct 24, 2008
FunnyPlumber
  • 43 Answers
SOURCE: fan won't turn on outside unit but has a hum noise
Be sure you have power, 220VAC to unit. You may have blown fises or tripped circuit breaker.
Posted on Jun 23, 2009
  • 21 Answers
SOURCE: Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Posted on Jul 11, 2009
  • 232 Answers
SOURCE: I have a Goodman GSC130241AB unit and the fan is
test the capacitor, if its bloated its bad, check the breaker. i would need some more info to help you more.
Posted on Sep 26, 2009
Goodman GMH95 furnace getting code 3.
humming noise from motor means it is seized
Jan 13, 2013 | Goodman Heating & Cooling
Air conditioner hum often
Is your AC unit a wall mounted unit or a cassette ? And do you know if it has a pump fitted or if its gravity fed drain system
Jul 08, 2012 | Goodman Heating & Cooling
Goodman Model CPLE24-1C - Two Units. One unit works fine, second outside unit will not engage.
It sounds like the run capacitor(silver can in control box) has failed if your comfortable around electrical you can change it; just replace it with the same rating as your other one. Make sure the power is off and write down it rating (i.e. 35+5 370 or 440 volts for a dual or 35 370 or 440 volts for a single).
Jul 08, 2012 | Goodman CPLE24-1 Air Conditioner
I have a goodman GMPN1 gas furnace It goes through the cycle but doesnt fire. I replaced the ignighter it is working but still wont fire.
have you checked the pressure switch and also to assure that the flu is clear? can you light the burner with a match and when you do how long does it run for? have you checked the clearance to the burner have you also assured that where the ignitor is pluged into is cleaned ive also noticed on another site there is a board issue with this model have you checked the board ? also have a look at this site as well its where I usually talk with other techs about issues they have with the goodman as well as other units http://www.contractortalk.com/f6/goodman-80-furnace-brand-new-wont-start-7006/ please message me back with the answers to the questions that I have asked and I await your reply Thanks again Rick
Jan 31, 2011 | Goodman Heating & Cooling
I turn my thermostat to the HEAT position, I hear the Thermostat click and the Furnace begins to hum but no air comes out of the vents. Also if i turn the fan to the ON position air will come out of the...
need to go to furnace and watch it...if your hearing a hum the enducer draft motor may have failed...it should start first if there is no fault codes...reset unit by unplugging furnace or in some cases turning power switch off...turn thermostat on heat and watch unit ..the small enducer draft motor should start first the a ignitor glows and the should light...goodman units have a control board with a light on control board when it fails should flash a code and on the door or inside on lable should give you what that code is...hope this helps good luck
Jan 07, 2011 | Goodman GMS90703BXA Heater
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Burner ignites and goes out (Goodman Gas-fired furnace)
The problem you have is water in the exhaust pipe.
Check to see if the pipe has sagged anywhere or if there is a trap in the line.
If you hear gurgling then it is definetly water....
Some times can be hard to find, even a pipe 1/4 full will cause problems. They are very sensitive to flue problems.
Make sure that the flue pipe either runs back to the furnace or out to the outside, a continuos slope either way witha high spot in the middle.
Also check the bottom drain of the blower if it has one, have had them plug and trap water also..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 24, 2009 | Goodman GMS90703BXA Heater
No Heat Goodman GDS80904BNA
If the hot surface ignitor comes on and fires the burners, and then shuts back down, you need to take a look at the flame sensor. It is a ceramic rod with a metal tip that rests in the pilot flame. When heated from burners, it sends a signal to the main control module, circuit board, which ever this unit is equipped with to keep the burners on. It is a safety to shut the burners down if there is a problem. Take some fine steel wool to clean the metal tip on this and this should take care of the problem. If this does not do it, then 99% of the time you have a faulty control board or module. It will have to be replaced.It is where this flame sensor connects.It will continue to drop out of the circuit, and the fan will start and run. You're T-stat is good or the Hot Surface ignitor would not glow. You will need to take as much info you can from the unit, Goodman and the control, all numbers with you.You can purchase this part at a appliance parts house, or air conditioning parts house. Please keep me informed, I would like to hear back from you. I hope this has given you some direction to follow.Good Luck,
Shastalaker7
Dec 08, 2009 | Goodman GDS80904BNA Open Flame Heater
All burners will not light on Goodman furnace
I have had problems like this before. Most of the time it is the connection between the burners. There are small slots that the gas runs thru to lite. Clean those with a brush and then try it. Rus
Oct 04, 2009 | Goodman CLQ36AR49 Air Conditioner
Oct 24, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
