Question about Exercise & Fitness
Sportcraft tx350 The belt seems to jerk backward & forward at the same time. Yesterday it stopped completely and then restarted.
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Posted on May 24, 2010
SOURCE: Have a sportcraft tx350 treadmill and it won't
I have a TX350 sportcraft treadmill and I keep getting shocked when I use it. How can I stop it ? I no longer have the user manual for it either. Can I get one ?
Posted on Mar 14, 2011
Zt2560
Remove blade drive belt. turn each blade by hand. Sounds as if you have bearing problems. Each spindle has an upper and lower bearing of the same size. They are notorious for going out! You can get them at most any auto parts store. Also check the tensioner pulley bearing. They go out quite often. As for the jerking, make sure the two drive disengage rods are fully in. Check tension on drive belt and belt. These belts get worn quickly. Be sure to blow the trash and dirt from your mower after each use. Especially the Hydraulic motors and the mower deck. This will save you lots of trouble. If you wash the mower, be sure and run the blades and Hrdroes to get water dried from bearings and pulleys and belts.
Oct 04, 2014 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Need to order a control board
I am not sure they carry these boards but most certainly worth a call is Allied Electronics. If they don't have one I know they will steer you the right direction.
May 14, 2014 | Sportcraft Tx350 Treadmill Motor Speed...
I have. Troy bilt snowblower, 3 yrs old and it just stopped moving forward or backward. The blower works and when I start the blower, the propulsion works a little bit then stops. I used yesterdAy and...
check the drive belt from engine to the transmission, sounds loose or even off. If belt and tension are ok check pulley for sheered key or loose coupling
Feb 09, 2013 | Garden
I have a TX350 sportcraft treadmill, works great, but shocks our hands everytime we use it and we lost the user manual when we moved a few years ago. ?
I am not a fitness expert but I did want to pass along a few resources in case they may be useful. Here is a parts list for the TX350, and here you can search for treadmill repair companies in case you need to have someone in your area take a look at it. Hopefully you can find a solution without needing to spend money on repairs, though.
Mar 14, 2011 | Sport & Outdoor - Others
At a stop car jerks forward with brakes applied
Are the engine rpms climbing when its jerking forward? seems like it could be a Transmission torque converter problem.
Apr 04, 2010 | 2004 Dodge Neon
Have a sportcraft tx350 treadmill and it won't stay on one speed. It speeds up.
Feb 25, 2010 | Exercise & Fitness
Exercise & Fitness Logo
19 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
