Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
Wireless Router i have a link sys router. i am trying to access it by feeding the ip address in the web page but it asking me my user name and password which i dont remember. i have tried to reset the router by pressing router reset button but its still not its asking same password and user name.
    Scholar:
  • 193 Answers
No u need to reset the box again like turn on the device and press and hold reset for atleast 40 seconds and check while u doing this the lights should blinks>and reboot and check
Posted on Oct 09, 2007
SOURCE:
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I need to get into my nat settings
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Netgear wgt624 v3 problem,cannot go to any sites
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
May 27, 2010 | NetGear WGT624 Wireless Router
Default use name and password with ip address of nortel bap120.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Mar 16, 2010 | Nortel BAP120 802.11a/b/g Wireless Access...
The DVD instructions ask for Cnnection type, username password, ip address and more. THe internet company says that the modem handled this information and the router suppose to catch the ip from the modem....
For that you need to access your router.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Then WAN settings configure your router as pppoe connection then add user name and password then Enable DHCP then save and restart router.
Dec 10, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
How do I make my connection secure to the internet? I have linksys wireless-G 2.4 GHz broadband router. The router is all hooked up but I believe the current connection is unsecured.
When you connected, did it ask you for a password? If not then it's obviously unsecured. Here's how to fix that... i have the same router.
On XP... open internet explorer... in the address bar, type in: 192.168.1.1
On vista.... click start menu...click on network...right click on router and select properties. Next, click on the "Network Device" tab at top of the new window. You will then see "Device Webpage"... click on the ip address to the right of that underlined in blue. It should ask you for a password... if you haven't set one manually the user is admin and the password is also admin. I recommend changing that to a manual password ASAP. Ok, after logging in, now you have the router's set up page in your web browser.
To make it secure:
On the set up page you now have open... you have a few selections that act like tabs: Setup, Wireless, Security, Access Restrictions, etc... Click on Wireless. After clicking on that, you have some tabs underneath wireless you can click on now.
Those selections should be: Basic wireless settings, Wireless security, Wireless MAC Filter, etc... Click on Wireless Security. There you should see disabled on the first drop down. Pick a WEP, WPA or whatever you prefer. I personnally use WEP with 64bit 10 hex and for the password, i use a 10 digit number.
After you have set up your password and security, click save settings at the bottom. After it's done processing the save, you can close the web browser. You are good to go now.
By the way, I recommended changing your password to access the router's set up page. Make absolutely sure you save that username/password in a safe location. If you forget it, there is nothing linksys can do to help you. I know from experience unfortunately.
Hope all this helped... Good Luck
Jul 02, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
