Question about Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A
MAXI hEAT CERAMIC HEATER CH 110
Won't turn on
Possible problems:
Adjustable thermostat dirty or worn out. Can bypass thermostat with a wire, if you do this thermostat will not function since it has been bypassed.
"Too hot safety piece" (located between large yellow and large white wire) is dirty between contacts. Disassemble, clean with sandpaper, reassemble.
Posted on Nov 29, 2014
  • 1 more comment
  • starlitopensky1
    starlitopensky1 Nov 29, 2014
    Possible problems:
  • starlitopensky1
    starlitopensky1 Apr 11, 2015
    Replace "too hot safety piece" with a safety heat fuse that melts when it reaches a certain temperature (piece can be found on eBay for about one dollar).
    The thermostat goes bad? Disconnect four wires from it and connect to each other (use a plastic cap over ends of wires and use electrical tape around it and wires to ensure safety).
    Space heater will probably work for decades, just clean dust out of fan/etc once in a while.
    I like the design of the heating plate and how the wires connect to it. Wish I could buy another, heater sold in 2004 I believe.
  • starlitopensky1
    Replace "too hot safety piece" with too-hot heat fuse (1 dollar eBay).
    Disconnect 4 wires from thermostat and connect them together. Use safety plastic twist cap on ends of wires and electrical tape around wires and cap.
    Occasionally remove dust from fan and on heater plate and wires.
    Heater should now last for decades.
Not heating, no fault codes, everything seems normal. Checked heat exchanger ok, flow switches ok, thermal reset ok just no power to the ceramic heating elements please help me ;-(
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Apr 28, 2015 | Dryers
Fan in my heater not wprking
Replace the fan motor. It could also be the control board depending on the heater.
Nov 26, 2013 | Lasko 5132 Ceramic Compact Heater
Won't stop ticking!!!! Why??
The noise could be from the expansion and contraction of the metal from heating up and cooling down. You could try loosen the mounting screws of the unit slightly to see if that helps.
Dec 14, 2012 | Williams (5009622) Ceramic Gas Wall...
Heater bionaire bch9224-cn no heat
The Bionaire BCH9224-CN is a ceramic space heater, one of apparently 4 related units. The 9224 is the tallest in the family and I also have the shorter BCH9212-CN. They are electric so I have no idea what all this talk about 'gas', 'pilot light' and 'flame' is. My 9224 failed in a way that seems quite common with Bionaire space heaters in general, namely, first the smell of burning electrical insulation, then a snap or pop accompanied by a flash of light out the lower side, and then no more heat. It is possible that the original questioner had this happen but wasn't around to witness it. Now it is possible that the failure is in the electrical control board but in my case (and in fact I'm betting for many or most of the Bionaire failures) it was a wire running to the ceramic heating block (element) that fried at the connection to the ceramic element. I would say it is very unlikely the failures of the Bionaires are in the ceramic heater blocks themselves, and in fact the 9224 and the 9212 (and I assume many or most of the other Bionaires) actually have two ceramic blocks/elements fastened together, one being used for the 750 watt heating and both for the 1500 watt heating. The central wire running to the blocks must support enough current (about 12.5 amps) for both of the blocks, whereas the wires to the individual blocks need half that (about 6.25 amps). In my 9224 unit the weak spot was clearly where the central, common wire was connected to the spade-like connector that was crimped onto the central, common tab of the ceramic block pair. At first I thought I'd just toss the thing but then I opened it up, did the autopsy and repaired it by replacing the 3 wires from the circuit board to the ceramic blocks with 14 gauge wire, and made the connection of the wires to the three soft metal (tin or tin alloy?) tabs of the ceramic blocks by carefully drilling holes in the tabs and bolting eye, crimp-type wire connectors to the tabs using small screws. Oddly enough I opened up the smaller unit (the BCH9212-CN) and it has the same ceramic element pair but no indication of burnt wires.
Jan 08, 2012 | Bionaire Heating & Cooling
My mother has a 3 brick wall unit...two of the bricks burn with a blue flame now instead of the inferred...should she replace that wall unit?
Hopefully, Becca the unit won't have to be replaced at this time. It sounds like the burner(s) is clogged and and needs to be cleaned To do this, turn the pilot light OFF and allow the unit to cool. Remove the front of the heater cabinet to access all of the inside workings. Carefully remove the 3 ceramic plaques and set them aside, where they won't get broken.Using a vacuum cleaner that has a hose, brush attachment and crevice tool. Vacuum all of the interior of the heater that you can reach with the brush attachment and crevice tool. Then turn your attention to the burner(s), Vacuum them thoroughly using the brush attachment, then switch to the crevice tool attachment and vacuum all the little holes on the top of the burner(s) thoroughly. Before reassembling the heater, carefully vacuum the ceramic plaques on both sides using the brush attachment. Be careful not to drop them. Then reinstall the plaques and the front of the heater cabinet.
Light the pilot and allow it to burn for 2 minutes, before turning the control knob to ON. Watch the plaques and the flames to see that burn as they should after turning it ON.
If the above didn't solve the problem, depending on the age of the heater, it may be time to replace it.
I hope this helped you and thanks for choosing FixYa.
Aug 16, 2011 | Reddy Heater RLP100 Portable Forced Air...
Heater shows red ready button, but won't turn on. Any ideas? I've already unplugged, tried multiple outlets and vacuumed the heating elements.... ???? What next ????
Turn temperature setting all the way up.
If that does not fix, turn temperature setting all the way down, turn heater off, unplug for at least 10 minutes.
Oct 05, 2010 | Lasko 5365 Ceramic Compact Heater
Not able to turn on and see anything on display of starite Spa / pool water heater. Any tips on where to start troubleshooting.
I just had my service heater light turn on with no heating and not able to increase or decrease any temp numbers. Any suggestions
Aug 30, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
No heat,ch.thermostat,water is circulating,blower goin strong .
Check the 'heater control valve'. This valve opens when u turn on the heat switch on the dash, so the hot coolant will flow thru the heater core and provide heat. So although the coolant is circulating in the engine, the valve controlling the flow to the heater core is stuck closed, or not working.
Nov 15, 2008 | 2000 Ford Focus
Open Questions:
See all Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A Questions
Heating & Cooling Logo
262 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
