Looking for the belt diagram to install new belts.
SOURCE: Serpentine belt in a 1995 Mercury sable
I have the same car and last night my belt slipped off. The top small pulley backed it's self out. The problem is in most cars the pulleys are reverse threaded so this wont happen, in ours not so much. The pully spins loose with the turn of the belt so it has to be tightened way down. IT's a pain. Here is a diagram I found and You need a 15mm wrench, which doesn't just come in most sets. Good Luck
The book says "Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise. Make sure spring keeper engages into slot." I would put a socket on the 15 mm pulley bolt and a long handle for leverage. Thats one tight spring.
SOURCE: I have a OLD Craftsman lawn tractor 36'' Drive belt diagram ?
go to sears.com click on parts and enter your mod#
