Question about Peg Perego Gaucho Rock'in
Peg pereo gauchonot starting - Peg Perego Gaucho Rock'in
Bought the electronic battleship , open it up , and there is more red pegs then the blue pegs .How many blue pegs suppose to be in the game?
I have the Hasbro Electronic Battleship Game. It includes 10 plastic ships, 84 red "hit" pegs and 168 white "miss" pegs! What make game have you bought? There will be more miss pegs than hits!
Dec 26, 2014 | Toys
I need game rules for 1978 Milton Bradley "Knock Out" game
So. I played this game years ago, and just pulled it out of my moms closet of games. Anyway, its similar to Othello, if you've ever played that. Start with putting pegs into the inner circle/hexagon, with every other peg facing opposite directions. Then the first player puts one of his/her pegs into the game, trapping their opponent's peg between theirs, and then pushing out the trapped peg and replacing it with their own. Once the board is full, the player with most pegs in it, wins. You can only push out pegs that are between the one you play and existing pegs from previous play.
Dec 12, 2014 | Milton Bradley Toys
How do i remove the seat for clean on safety 1st walker
Do not just pull the pegs as I have previously read, you have to unbuckle the other buckles then start with one side and twist the seat until the peg is returned and released from its slot..... P.S I know that my response is late but I would hope that it will help someone because I had a hard time figuring this out!
Jan 06, 2013 | Safety 1st Sound n Lights Activity Walker...
Peg Perego Apache Jeep electrical problems.
start at the battery, then check the foot pedal then the shifter switch
Jul 14, 2010 | Peg Perego John Deere Gator HPX Ride on...
Our Peg Perego Gator has a brand new battery yet it won't run. It started out with the reverse not working, then we lost the fast gear and now it doesn't work at all. Any advice?
I would check to see if both wheels are spinning in high.
If only one spins, then it may have a loose connection on one of the motors.
You can also get the specific peg perego gator switches from the guys at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
They also have a phone number that you can call them to explain theproblem with the vehicle, they seem to know a lot about them.
Hope this helps.
Feb 14, 2010 | Peg Perego John Deere Gator HPX
I need a new batery charger for my peg perego gator hpx 12 volt. where can i get one?
I bought my Peg Perego Charger at
http://www.shopjandl.com/mecb0034.html
They fit the 12 volt blue batteries for Peg Perego.
Hope this helps
Jul 09, 2009 | Peg Perego John Deere Gator HPX Ride on...
Re: professor laytons seven squares
Not my brilliance I'm afraid, but found the answer on another website, have copied in below - it does work!
It is very complicated to explain but i'll try as best as I can. 1- First make a small square in the top left corner.(This is the only one that isn't at 45 degrees)
2- Next go to the far bottom left corner and make a small 45 degree (lop sided) square leaving only one peg in the middle.
3- Copy the same thing as you did for the 2nd square but this time in the far top right corner.
4- Use the peg that is in the centre of the square in the bottom left corner(2) and draw a line to the peg on the far right at the very bottom. Then draw a line to the middle peg on the far right. Then draw a line to the peg that is on the 2nd row from the top and 3 columns in from the left. Then complete the square connecting up the other side.
5- Start from the peg that is on the very far right that is free and connect it to the peg that is free at the very bottom. Then connect that to the peg that is free on the far left. Then connect it to the peg at the very top (out of the 2 that are free) on the right. Then complete the square.
6- At the very top start at the free peg and connect it to the free peg on the right that is in the centre of the small 45 degree square. Then connect this to the free peg in the centre of 4 other free pegs. Then connect that to the free peg that is furthest to the left and then complete that square.
7- As there are only 4 pegs left this should be easy to see a small 45 degree square. Hope this helps and didn't confuse you too much.
Nov 24, 2008 | Nintendo Professor Layton & the Curious...
Removing Seats
on the left and right side of the cloth seat there are white pegs. Starting with the rear pegs... the white peg towards the rear pulls straight out, pull hard. The one towards the front, slides forward and then pulls out.
Jan 13, 2007 | Baby Trend Caravan Lite LX Twin Seat...
Peg Perego Gaucho Rock'in Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
